Webcast-Catalyst9k
Network-id in dmvpn................!
hi all,
What is the significance of network-id in DMVPN config? I tried googling it and found that it has to be globally unique no., what is the significance of globally uniqueness in it?
--gaurav
1 ACCEPTED SOLUTION
Bronze
Re: Network-id in dmvpn................!
A router can run >=1 DMVPNs and the ID is to differentiate one NHRP domain running on one tunnel interface from another running on another interface. You also would key the GRE tunnel - using "tunnel key " - associated with a particular tunnel interface.
1 REPLY
Bronze
124
