Network Load Balancing Microsoft
I has in my network thos cluster using NLB Microsoft they are connect to a pair of 4507R using HSRP, but i got some mesagge of hostflapping between his port, some one can suggest a configuration to use to avoid that.
1 REPLY
Re: Network Load Balancing Microsoft
When you do NLB what microsfot does is uses same MAC ID for both interfaces on servers.
Thats why you will be reciving host flapping error between the ports. There is nothing to worry about that.
Rate post if helpfull.
Sures Jain
979
