Network Segments and DHCP Server
Muhammad Haseeb
Suppose in company, there are 9 departments . The LAN is segmented with 5 routers (Subnets). If I create a DHCP Pool Range in Windows server 2008 , Will it assign IP Addresses to All the hosts of all five segments . Given we choose Class B Ip adressing Scheme? Please answer
Pawan Sharma
Yes it would assign IP address to all different 9 VLANs. Just make sure to use "IP Helper-Address" command on the layer 3 devices used for inter-vlan routing.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
