Community Member
network setup for 250 employee base company
Dear Friends ,
I have two cisco 1841 router , but for one router searil port is gone only two interface FE are working , and we have One L3 and 10 L2 switches and one ASA 5510 firewall we have , can any one suggest me with these how i can build secure network , both isp's link should work as active.
Community Member
Re: network setup for 250 employee base company
The requirements mentioned are not clear. I am assuming quite a few things here ;). you can ask one isp to provide an ethernet link and connect one link per router. and then connect both these router to the ASA and then use the L3 and L2 switches in the LAN. If you want multiple VLAN, use the L3 switch as the VLAN gateway and route to ASA. ASA can check if the links are up and route based on the same. You will need to configure tracking on ASA to achieve this.
