07-03-2008 02:35 AM - edited 03-05-2019 11:58 PM
Hi all, when we talk about network speeds and monitoring the network, do we talk in bits and megabits? some people think its bytes!!
07-03-2008 02:51 AM
First of all the difference between MB/Mb and KB/Kb =
the Big "B" is Bytes
and the small "b" is bits
In our case, Networks its bits ( Mbps,Kbps etc.)
Hope this answers your query.
07-03-2008 04:26 AM
thats excellent thanks
07-03-2008 04:15 AM
Bits are used in networks since we want to represent binary modulation rates and we're usually dealing with serial transmission. (There's also Baud, often used to be used with dial-up modems, which measures signal transition rates; often incorrectly used as being the same as bps.)
Bytes are usually significant to display characters (i.e. ASCII, EBCDIC) and often don't correspond to non-character data usage. For example, non-network people "knowing" that a byte is 8 bits usually don't understand why 10 Mbps Ethernet doesn't deliver 1.25 MBps. (For fun, explain how RS232's usage of 1, 1 and 1/2, or 2 stop bits impacts effective transmission rate, especially when using 1 and 1/2 stop bits.)
BTW: Bytes came from being part of a machine "word" which often stored a single display character and could also often be directly addressed.
