New 4503 with Sup II+TS 10/100/1000 interface are down state
Hi all.
I was trying to connect our two new 4503 switches to each other via port g1/1-12 on the supervisor modul..
Mod Ports Card Type Model Serial No.
1 20 Sup II+TS 10/100/1000BaseT (RJ45), SFP WS-X4013+TS JAE10318CQ5
2 24 10/100/1000BaseT (RJ45) WS-X4424-GB-RJ45 JAE102022K6
M MAC addresses Hw Fw Sw Status
1 0018.187a.5fc0 to 0018.187a.5fd3 1.5 12.2(20r)EW1 12.2(25)EWA4 Ok
2 0016.c73c.ed28 to 0016.c73c.ed3f 1.8 Ok
What ever I did I was not able to get the interface in a up state. If I moved the cable down to switch modul I got interface up right away. Why is this happening?. Are there any command I need to enable to supervisor interfaces with??...
I noticed when I start the switches, the LED`s on those ports dont seems to run the check... There is also 8 SFP ports there, who looked liked the check was run.
What do I need to do to enable those supervisor ports??.. In the documentation it say that this ports are in up state by default.. If this only was a problem on one switch I would have suspected the modul, but it is on both the NEW switches..
JP
Re: New 4503 with Sup II+TS 10/100/1000 interface are down state
It would be quicker if we could have a look at your config. There are several possible mistakes that might cause this.
1: ports not configured as switchport
2: vlans not added to the vlan database
3: vlan1 administratively down
Please verify this and post your config if these tips do not resolve the problem.
Leo
All ports are as they should be.. here are the config:
vlan 1000 is not administrativ down. so are not vlan 1...
Problem here is something else than this basic
sw 1
interface Vlan1000
description ### Mot Internett brannmur#1 ###
ip address 10.0.1.1 255.255.255.0
interface GigabitEthernet1/12
switchport access vlan 1000
sw 2
interface Vlan1000
description ### Mot Internett brannmur#2 ###
ip address 10.0.1.2 255.255.255.0
sh run int g1/12
Building configuration...
Current configuration : 66 bytes
end
L3-Core#2#sh int g1/12
GigabitEthernet1/12 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 0018.187a.5f8b (bia 0018.187a.5f8b)
If I do exactly the same on the switch modul everything is OK...
What is happening?.. there have to be something specially that I need to do..
OK, you might have a compatability issue here.
Are you sure that the combination of hardware & IOS is supported?
Please post a sh ver + sh mod if we should help you verifying this.
Leo
L3-Core#1#sh mod all
Chassis Type : WS-C4503
Power consumed by backplane : 0 Watts
L3-Core#1#sh ver
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 23-Sep-05 13:31 by ssearch
Image text-base: 0x10000000, data-base: 0x114DFF08
ROM: 12.2(20r)EW1
Dagobah Revision 225, Swamp Revision 4
L3-Core#1 uptime is 23 hours, 1 minute
System image file is "bootflash:"
cisco WS-C4503 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX102002HJ
MPC8245 CPU at 267Mhz, Supervisor II+TS
Last reset from PowerUp
2 Virtual Ethernet interfaces
44 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
I have found the problem.. these ports dont support autodetection of the cable type, so when i put in a straight trough cable here between the switches it did not detect it.. I pluged the cable in top my computer and the line came up
Jens P
Thanks for explaning.
This saves me the time to investigate your request.
Leo
251
