new router connection problem
T1 connection 3600 to 3600
changed one side from 3600 to 2600, exact same configs on the Serial
2600 can ping 3600
3600 can't ping but show cdp of 2600
2600 to 3600 - can't get beyond the router inside the network.
what is wrong with my config?
Re: new router connection problem
Can you paste your config at both ends?
thanks
had to switch back to main router but here are the configs from all 3 routers:
Branch Office 3640
Branch3640#show int Serial1/0:0
Serial1/0:0 is up, line protocol is up
Hardware is DSCC4 Serial
Description: Line To NY
Internet address is 212.150.232.117/30
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1634638 seconds on reset, Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 18w3d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 16
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/7/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 384 kilobits/sec
5 minute input rate 0 bits/sec, 1 packets/sec
88099334 packets input, 817815933 bytes, 0 no buffer
Received 1307448 broadcasts, 0 runts, 2 giants, 0 throttles
26516 input errors, 2298 CRC, 24198 frame, 0 overrun, 0 ignored, 20 abort
86028637 packets output, 1995405079 bytes, 0 underruns
0 output errors, 0 collisions, 75 interface resets
4 carrier transitions
Timeslot(s) Used:1-8, SCC: 0, Transmitter delay is 0 flags
Branch3640#show run int s1/0:0
Building configuration...
Current configuration : 153 bytes
interface Serial1/0:0
description Line To NY
ip address 212.150.232.117 255.255.255.252
ip nat outside
ip policy route-map deny-dos
end
Branch3640#show ip route
Gateway of last resort is A.B.C.D to network 0.0.0.0
212.150.233.0/28 is subnetted, 1 subnets
S 212.150.233.176 [1/0] via 212.150.232.118
212.150.232.0/30 is subnetted, 2 subnets
S 212.150.232.16 [1/0] via 212.150.232.118
C 212.150.232.116 is directly connected, Serial1/0:0
Main Office 3640
Main3640#show int Serial2/0
Serial2/0 is up, line protocol is up
Hardware is QUICC with integrated T1 CSU/DSU
Description: Branch1
Internet address is 212.150.232.118/30
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 91846
Output queue: 0/1000/64/91840 (size/max total/threshold/drops)
Conversations 0/18/256 (active/max active/max total)
239108891 packets input, 2287448228 bytes, 0 no buffer
Received 5646002 broadcasts, 44 runts, 12354 giants, 0 throttles
2895649 input errors, 1104108 CRC, 1013460 frame, 0 overrun, 0 ignored, 778
077 abort
251349077 packets output, 1815526810 bytes, 0 underruns
0 output errors, 0 collisions, 4852 interface resets
52 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Main3640#show run int Serial2/0
Current configuration : 156 bytes
interface Serial2/0
description Branch1
ip address 212.150.232.118 255.255.255.252
ip nat outside
service-module t1 timeslots 1-8
end
212.150.232.0/30 is subnetted, 1 subnets
C 212.150.232.116 is directly connected, Serial2/0
Main Office 2611 - this is now disconnected, when the line is here it does show up
newMain2611#show int Serial0/0
Serial0/0 is down, line protocol is down
Hardware is PQUICC with Fractional T1 CSU/DSU
Last input never, output never, output hang never
Conversations 0/0/256 (active/max active/max total)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
newMain2611#show run int Serial0/0
Current configuration : 163 bytes
interface Serial0/0
description Branch1
ip nat outside
end
157
