Community Member
New SUP for 4500?
Has anyone heard of the new SUP coming out for the 4500 series? Iam trying to get more info on it. I am running SUPV 10 gig and need more CPU.
Re: New SUP for 4500?
Hi Mark,
There is a new Sup320 (320Gbps) coming for 4500 in another month's time.I am not sure about the avialbility dates on the same.
We do have support for enhanced routing capabilities as well as MPLS support on this.Please check the same with your Cisco's account team.
HTH, Please rate if it does.
Ankur
Please see my post below on the same.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde9789
Let me know if you have any queries on this and I will be able to help you.
HTH,Please rate if it does.
-amit singh
Amit / Ankur,
What would be the throughput available per slot. The present 4506 supports 6 Gbps per slot.
I think i had heard that the new SuP will support 24 Gbps per slot. Is it correct?
Narayan
Narayan,
Yes, its 24Gbps/Slot. There is a new E series line card coming for the same 48 port 10/100/1000 which will use the same slot capacity.
-amit singh
Thanks amit for the confirmation..
Is there any 24 SFP module in line so that i have 1 GBps capacity per port?
Narayan
Narayan,
Not right now. It shoule be there sometime in next year. I will update you if I hear something soon on this.
HTH,
-amit singh
149
