Newb VLAN question...
Going over some other questions this morning, I ran into one I had myself but forgot to ask...say we have:
interface FastEthernet1/0/1
switchport trunk allowed vlan 3,4,6-9,300
switchport mode trunk
When you have the cmd
sw mo tr
doesnt that mean all VLANs are allowed? By having the line
Is this config not allowing all other VLANs?
1 ACCEPTED SOLUTION
Blue
Re: Newb VLAN question...
Hello:
By default, a dot1q trunk configured on a Cisco device will allow all vlans that are configured on the switch.
You can prune some vlans off the trunk by using the "allowed" keyword.
"doesnt that mean all VLANs are allowed?"
Yes.
"By having the line switchport trunk allowed vlan 3,4,6-9,300 Is this config not allowing all other VLANs?"
Correct. Only vlans 3,4,6,7,8,9 and 300 will be allowed on that trunk.
Victor
1 REPLY
Blue
Hello:
Yes.
Victor
129
