11-04-2011 02:28 AM - edited 03-07-2019 03:12 AM
Good morning,
In my lab, there are some machines that are connected using Cisco 2950 switches. Those machines belong to a VLAN.
Now I need to modify the VLAN settings of the machines and as such I also need to modify the VLAN settings on the ports on the Cisco switches.
In order to do this, first I need to login to those switches, but due to a lack of knowledge transfer, I don't have the password. Is the some generic password?
Second I will need to modify the VLAN settings on each individual port. How can I do this?
Dominique
11-04-2011 02:41 AM
Are these brand new switches or second hand? What type of modifications are you looking to do to the VLANs?
11-04-2011 03:09 AM
there is no password by default on the switch. How are you connecting to it? if it is via a console cable what password is it asking, the exec password or the privileged mode password? If it is connected to another switch or router can you do a sh cdp nei detail on this neighbouring device to find out the management IP then try to login via telnet/ssh and maybe there is no login password there.Anyway if you're locked out of the switch you'll have to do a password recovery to login or ask your colleagues the credentials.
here is the link for password recovery: http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
For changing VLAN mapping of a port:
switch# enable
switch(config)# switchport access vlan
This will only work if the switch is in VTP server or transparent mode: to verify switch# sh vtp status
then to see the mapping is done correctly : switch# sh vlan brief and you should see the ports active for the VLAN id
Regards.
Alain.
