04-12-2012 06:57 AM - edited 03-07-2019 06:05 AM
I have a 3925. I have one int on the same subnet as our internet connection (gi0/1) and one on the subnet for our local traffic (gi0/2) and an ip route for that to get out. The problem I am having is that it is not routing the local traffic to the next hop (ISP router (ip of 10.250.250.1)) that is on the same subnet as gi0/1. Here is my current config. Please be aware that my Cisco knwledge is very limited. This router was also setup befoe I was part of the project, and that person has since left. Any help would be greatly appreciated. If you need more of the config let me know. Thanks.
interface Loopback0
ip address 10.200.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description CAJ LAN connection
ip address 10.245.245.1 255.255.255.248
duplex full
speed 1000
interface GigabitEthernet0/1
Description ISP Connection
ip address 10.250.250.2 255.255.255.252
duplex full
speed 100
interface GigabitEthernet0/2
description Test Laptop
ip address 10.100.100.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Null0
ip route 10.1.0.0 255.255.0.0 10.245.245.2
ip route 10.10.0.0 255.255.0.0 10.245.245.2
ip route 10.100.100.0 255.255.255.0 10.250.250.1
ip route 10.250.250.0 255.255.255.0 10.250.250.1
logging trap debugging
logging 192.168.100.4
access-list 23 permit 1.1.1.0 0.0.0.255
access-list 99 permit 10.1.40.90
route-map MESDG permit 10
match ip address 99
set ip next-hop 72.14.100.1
04-12-2012 07:07 AM
you have your default route pointing at Null0. It should be pointing at your ISP router out of G0/1.
Dan
04-12-2012 07:11 AM
here are the commands I ran:
MurrayDC3925(config)#no ip route 0.0.0.0 0.0.0.0 Null0
MurrayDC3925(config)#ip route 0.0.0.0 0.0.0.0 Gi0/1
correct?
04-12-2012 07:13 AM
yeah, or you could just use the next hop for 0.0.0.0 to be the IP address of the ISP router.
Dan
04-12-2012 08:09 AM
I made that change, but am still unable to ping 10.250.250.1 from my test laptop at 10.100.100.2.
04-12-2012 08:22 AM
can you ping that IP from the router?
04-12-2012 08:31 AM
yes. and the next hop in the ISP chain.
04-12-2012 08:36 AM
ok, can the client ping the router interface?
04-12-2012 10:03 AM
It cannot.
I actually also tried to ping the IP of gi0/2 from the router and it fails also.
04-12-2012 10:01 AM
The ISP doesnt have knowledge of the network your laptop is on Brad. ISP only knows the network to which it is directly connected. You should be able to ping the ISP with source interface gig0/1 from the router. For you to ping the ISP you need to set up a source nat to the gig0/1 interface.
04-12-2012 10:12 AM
again, please excuse my inexperiance. How would this be done? Or can you point me in the direction to find out the information?
04-13-2012 02:30 AM
ok then Brad, just to confirm you cannot ping 10.250.250.2 from the client machine on 10.245.245.x?
Im assuming that the clinet can ping its default gateway?
As both networks are directly connected to the router, there shouldnt be an issue - can you post the static routes you have configured?
Dan
04-13-2012 02:32 AM
as the other person said, the ISP router doesnt know how to get back to the source network so unless you have a routing protocol running on both routers, you will need a static route on the ISP router for the client router (via 10.250.250.2).
Dan
04-13-2012 05:30 AM
I cannot ping the IP of GI0/2 (10.100.100.1) from the router (ssh'd into the management port with is 10.245.245.x)
I cannot ping the IP of GI0/1 (10.250.250.2) from a laptop that is plugged into Gi0/2 with a static address of 10.100.100.2.
Here are my static routes at this time
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
I'm had more but removed them during testing.
04-13-2012 06:10 AM
Can your laptop ping 10.100.100.1?
I assume you are plugging straight into the router? If so are you using a straight through cable or cross over?
