Newbie - routing question
winanjaya
Dear Expert,
I am very new to CISCO, I have 2 networks A & B
A is on 172.16.1.0/24, router is on 172.16.1.2
B is on 172.16.4.0/24, router is on 172.16.4.1
in Network B, there is also had internal network 192.168.210.0
currently, from network A (172.16.1.0/24) I able to connect to 172.16.4.0/24 but how to connect network 192.168.210.0 ?
pls help
6 Replies 6
hoogen_82
Level 4
Level 4
You need to enable some kind of routing static or dynamic, so that your network would be reachable. This can be answered better if you post your n/w diagram and explain what you are doing.
A (172.16.1.0/24) -> B (172.16.4.0/24)
B1 (192.168.210.0/24)
pls help
What is the ip addresses of the connection linking between the 2 routers, and what are the LAN ips behind each ?
BR,
Mohammed Mahmoud.
Router A (172.16.1.0/24) 172.16.254.25
Router B (172.16.4.0/24) 172.16.254.26
LAN IPs behind of A: is 172.16.1.0/24
LAN IPs behind of B are:
172.16.4.0/24 and 192.168.210.0/24
pls help
& TIA
Rotuer A:
ip route 172.16.4.0 255.255.255.0 172.16.254.26
ip route 192.168.210.0 255.255.255.0 172.16.254.26
Router B:
ip route 172.16.1.0 255.255.255.0 172.16.254.25
HTH, please rate using the below scroll box if it does help,
Mohammed Mahmoud.
i think in addition to the above posts u need to configure secondry address on the interface of router B to enable proper routing for that subnet.
Mahmood
