05-01-2014 06:53 AM - edited 03-07-2019 07:17 PM
Hello Forum Team!
In order to configure the port speed and duplexing (change to 100Mbps/Full-duplex from auto mode) on a Nexus 2248TP interface, does the port needs to be down,.i.e, no link?
Thanks in advanced for your support!
Solved! Go to Solution.
05-01-2014 03:09 PM
No, you can do it anytime.
05-01-2014 03:09 PM
05-02-2014 06:34 AM
Hello and thanks for reply;
I was trying to configure port speed and duplexing on a 2148. This FEX model only works at 1000Mbps as I later found out on the documentation.
Thanks again for your support.
12-19-2017 08:50 AM
And about the 2248TP, does it works at 100Mpbs? And is it able to auto-negotiation at 100Mpbs?
