Community Member
Nexus 2248TP port speed and duplexing
Hello Forum Team!
   In order to configure the port speed and duplexing (change to 100Mbps/Full-duplex from auto mode) on a Nexus 2248TP interface, does the port needs to be down,.i.e, no link?
Thanks in advanced for your support!
1 ACCEPTED SOLUTION
Community Member
No, you can do it anytime.
Community Member
Community Member
Hello and thanks for reply;
      I was trying to configure port speed and duplexing on a 2148. This FEX model only works at 1000Mbps as I later found out on the documentation.
Thanks again for your support.
Community Member
Re: Hello and thanks for reply;
And about the 2248TP, does it works at 100Mpbs? And is it able to auto-negotiation at 100Mpbs?
171
