01-28-2014 10:39 AM - edited 03-07-2019 05:51 PM
I cheked my logs and found out below...
I am assuming it is a cabling issue ??? please confirm....
are there any issues with the configs???
2014 Jan 28 18:26:33 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/22, vlan 481 down
2014 Jan 28 18:26:33 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/22 is down (Link failure)
2014 Jan 28 18:26:33 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/21, vlan 481 down
2014 Jan 28 18:26:33 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/21 is down (Link failure)
2014 Jan 28 18:26:33 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/23, vlan 481 down
2014 Jan 28 18:26:33 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/23 is down (Link failure)
2014 Jan 28 18:26:33 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/22 is down
2014 Jan 28 18:26:33 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/21 is down
2014 Jan 28 18:26:33 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/23 is down
2014 Jan 28 18:26:33 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/24, vlan 481 down
2014 Jan 28 18:26:33 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/24 is down (Link failure)
2014 Jan 28 18:26:33 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/24 is down
2014 Jan 28 18:26:36 %ETHPORT-5-SPEED: Interface Ethernet103/1/21, operational speed changed to 1 Gbps
2014 Jan 28 18:26:36 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/21, operational duplex mode changed to Full
2014 Jan 28 18:26:36 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/21, operational Receive Flow Control state changed to off
2014 Jan 28 18:26:36 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/21, operational Transmit Flow Control state changed to on
2014 Jan 28 18:26:36 %ETHPORT-5-SPEED: Interface port-channel220, operational speed changed to 1 Gbps
2014 Jan 28 18:26:36 %ETHPORT-5-IF_DUPLEX: Interface port-channel220, operational duplex mode changed to Full
2014 Jan 28 18:26:36 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel220, operational Receive Flow Control state changed to off
2014 Jan 28 18:26:36 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel220, operational Transmit Flow Control state changed to on
2014 Jan 28 18:26:36 %ETHPORT-5-SPEED: Interface Ethernet103/1/22, operational speed changed to 1 Gbps
2014 Jan 28 18:26:36 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/22, operational duplex mode changed to Full
2014 Jan 28 18:26:36 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/22, operational Receive Flow Control state changed to off
2014 Jan 28 18:26:36 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/22, operational Transmit Flow Control state changed to on
2014 Jan 28 18:26:36 %ETHPORT-5-SPEED: Interface Ethernet103/1/24, operational speed changed to 1 Gbps
2014 Jan 28 18:26:36 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/24, operational duplex mode changed to Full
2014 Jan 28 18:26:36 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/24, operational Receive Flow Control state changed to off
2014 Jan 28 18:26:36 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/24, operational Transmit Flow Control state changed to on
2014 Jan 28 18:26:36 %ETHPORT-5-SPEED: Interface Ethernet103/1/23, operational speed changed to 1 Gbps
2014 Jan 28 18:26:36 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/23, operational duplex mode changed to Full
2014 Jan 28 18:26:36 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/23, operational Receive Flow Control state changed to off
2014 Jan 28 18:26:36 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/23, operational Transmit Flow Control state changed to on
2014 Jan 28 18:26:46 %ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet103/1/21 is operationally individual
2014 Jan 28 18:26:46 %LACP-FEX103-5-LACP_SUSPEND_INDIVIDUAL: LACP port Ethernet103/1/21(0x1f660500) of port-channel port-channel220(0x160000db) not receiving any LACP BPDUs suspe
nding (individual) port
2014 Jan 28 18:26:46 %ETHPORT-5-IF_TRUNK_UP: Interface Ethernet103/1/21, vlan 481 up
2014 Jan 28 18:26:46 %ETHPORT-5-IF_UP: Interface Ethernet103/1/21 is up in mode trunk
2014 Jan 28 18:26:46 %ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet103/1/22 is operationally individual
2014 Jan 28 18:26:46 %ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet103/1/24 is operationally individual
2014 Jan 28 18:26:46 %LACP-FEX103-5-LACP_SUSPEND_INDIVIDUAL: LACP port Ethernet103/1/22(0x1f660540) of port-channel port-channel220(0x160000db) not receiving any LACP BPDUs suspe
2014 Jan 28 18:26:46 %ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet103/1/23 is operationally individual
2014 Jan 28 18:26:46 %LACP-FEX103-5-LACP_SUSPEND_INDIVIDUAL: LACP port Ethernet103/1/24(0x1f6605c0) of port-channel port-channel220(0x160000db) not receiving any LACP BPDUs suspe
2014 Jan 28 18:26:46 %ETHPORT-5-IF_TRUNK_UP: Interface Ethernet103/1/22, vlan 481 up
2014 Jan 28 18:26:46 %ETHPORT-5-IF_UP: Interface Ethernet103/1/22 is up in mode trunk
2014 Jan 28 18:26:46 %LACP-FEX103-5-LACP_SUSPEND_INDIVIDUAL: LACP port Ethernet103/1/23(0x1f660580) of port-channel port-channel220(0x160000db) not receiving any LACP BPDUs suspe
2014 Jan 28 18:26:46 %ETHPORT-5-IF_TRUNK_UP: Interface Ethernet103/1/24, vlan 481 up
2014 Jan 28 18:26:46 %ETHPORT-5-IF_UP: Interface Ethernet103/1/24 is up in mode trunk
2014 Jan 28 18:26:46 %ETHPORT-5-IF_TRUNK_UP: Interface Ethernet103/1/23, vlan 481 up
2014 Jan 28 18:26:46 %ETHPORT-5-IF_UP: Interface Ethernet103/1/23 is up in mode trunk
After few seconds and then i see again link failure....
2014 Jan 28 18:31:00 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/22, vlan 481 down
2014 Jan 28 18:31:00 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/22 is down (Link failure)
2014 Jan 28 18:31:00 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/21, vlan 481 down
2014 Jan 28 18:31:00 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/21 is down (Link failure)
2014 Jan 28 18:31:00 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/22 is down
2014 Jan 28 18:31:00 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/21 is down
2014 Jan 28 18:31:00 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/24, vlan 481 down
2014 Jan 28 18:31:00 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/24 is down (Link failure)
2014 Jan 28 18:31:00 %ETHPORT-5-IF_TRUNK_DOWN: Interface Ethernet103/1/23, vlan 481 down
2014 Jan 28 18:31:00 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet103/1/23 is down (Link failure)
2014 Jan 28 18:31:01 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/24 is down
2014 Jan 28 18:31:01 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet103/1/23 is down
2014 Jan 28 18:31:03 %ETHPORT-5-SPEED: Interface Ethernet103/1/22, operational speed changed to 1 Gbps
2014 Jan 28 18:31:03 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/22, operational duplex mode changed to Full
2014 Jan 28 18:31:03 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/22, operational Receive Flow Control state changed to off
2014 Jan 28 18:31:03 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/22, operational Transmit Flow Control state changed to on
2014 Jan 28 18:31:03 %ETHPORT-5-SPEED: Interface Ethernet103/1/21, operational speed changed to 1 Gbps
2014 Jan 28 18:31:03 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/21, operational duplex mode changed to Full
2014 Jan 28 18:31:03 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/21, operational Receive Flow Control state changed to off
2014 Jan 28 18:31:03 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/21, operational Transmit Flow Control state changed to on
2014 Jan 28 18:31:03 %ETHPORT-5-SPEED: Interface port-channel220, operational speed changed to 1 Gbps
2014 Jan 28 18:31:03 %ETHPORT-5-IF_DUPLEX: Interface port-channel220, operational duplex mode changed to Full
2014 Jan 28 18:31:03 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel220, operational Receive Flow Control state changed to off
2014 Jan 28 18:31:03 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel220, operational Transmit Flow Control state changed to on
2014 Jan 28 18:31:04 %ETHPORT-5-SPEED: Interface Ethernet103/1/24, operational speed changed to 1 Gbps
2014 Jan 28 18:31:04 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/24, operational duplex mode changed to Full
2014 Jan 28 18:31:04 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/24, operational Receive Flow Control state changed to off
2014 Jan 28 18:31:04 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/24, operational Transmit Flow Control state changed to on
2014 Jan 28 18:31:04 %ETHPORT-5-SPEED: Interface port-channel220, operational speed changed to 1 Gbps
2014 Jan 28 18:31:04 %ETHPORT-5-IF_DUPLEX: Interface port-channel220, operational duplex mode changed to Full
2014 Jan 28 18:31:04 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel220, operational Receive Flow Control state changed to off
2014 Jan 28 18:31:04 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel220, operational Transmit Flow Control state changed to on
2014 Jan 28 18:31:04 %ETHPORT-5-SPEED: Interface Ethernet103/1/23, operational speed changed to 1 Gbps
2014 Jan 28 18:31:04 %ETHPORT-5-IF_DUPLEX: Interface Ethernet103/1/23, operational duplex mode changed to Full
2014 Jan 28 18:31:04 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet103/1/23, operational Receive Flow Control state changed to off
2014 Jan 28 18:31:04 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet103/1/23, operational Transmit Flow Control state changed to on
2014 Jan 28 18:31:13 %ETH_PORT_CHANNEL-4-PORT_INDIVIDUAL: port Ethernet103/1/22 is operationally individual
interface port-channel220
description server-1 PO220
switchport mode trunk
switchport trunk allowed vlan 481
interface Ethernet103/1/21
description server-1,Trunk
channel-group 220 mode active
interface Ethernet103/1/22
interface Ethernet103/1/23
interface Ethernet103/1/24
01-28-2014 11:48 AM
The logs are indicating that the FEX is not receiving LACPDU from the server. Check with the server team to make sure they've configured the server to use 802.3ad Link Aggregation with LACP, sometimes called 802.3ad dynamic.
If the server only supports static link aggregates, then you should reconfigure the FEX ports with the channel-group 220 mode on command.
01-28-2014 12:32 PM
Steve,
Thanks for the reply....
but what about "link failure" logs ??? is it layer-1 issue ??? i see it happens for every few minutes.
01-28-2014 01:40 PM
What's the upstream Nexus switch? The Nexus 7000 has a feature called lacp suspend-individual enabled by default which will disable the physical interface if LACPDU are not being received.
The timings don't look exactly as I'd expect, but I'm struggling to believe that all four links are flapping due to cable issues.
Can you paste the output of show lacp summary and show lacp counters when the links are operational and when they're down? I'm interested to see how things behave once the LACP issues are resolved.
01-28-2014 02:00 PM
steve,
upstream switches are 6500
sh lacp internal event-history interface ethernet 103/1/21 (same events all interfaces)
961) FSM:
Previous state: [LACP_ST_INDIVIDUAL_OR_DEFAULT]
Triggered event: [LACP_EV_LACP_DOWN_OR_PORT_DOWN]
Next state: [LACP_ST_PORT_IS_DOWN_OR_LACP_IS_DISABLED]
962) FSM:
Previous state: [LACP_ST_PORT_IS_DOWN_OR_LACP_IS_DISABLED]
Triggered event: [LACP_EV_LACP_ENABLED_AND_PORT_UP]
Next state: [LACP_ST_DETACHED_LAG_NOT_DETERMINED]
963) FSM:
Previous state: [LACP_ST_DETACHED_LAG_NOT_DETERMINED]
Triggered event: [LACP_EV_RECEIVE_PARTNER_PDU_TIMED_OUT]
Next state: [FSM_ST_NO_CHANGE]
964) FSM:
965) FSM:
Triggered event: [LACP_EV_RECEIVE_PARTNER_PDU_TIMED_OUT_II_INDIVIDUAL]
Next state: [LACP_ST_INDIVIDUAL_OR_DEFAULT]
966) FSM:
967) FSM:
968) FSM:
969) FSM:
970) FSM:
971) FSM:
972) FSM:
973) FSM:
974) FSM:
975) FSM:
Nexus-5K-A# sh lacp counters interface port-channel 220
LACPDUs Marker Marker Response LACPDUs
Port Sent Recv Sent Recv Sent Recv Pkts Err
port-channel220
Ethernet103/1/21 64793 0 0 0 0 0 0
Ethernet103/1/22 106791 60 0 0 0 0 0
Ethernet103/1/23 106773 60 0 0 0 0 0
Nexus-5K-A# sh lacp neighbor interface port-channel 220
Flags: S - Device is sending Slow LACPDUs F - Device is sending Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
port-channel220 neighbors
Partner's information
Partner Partner Partner
Port System ID Port Number Age Flags
Eth103/1/21 0,0-0-0-0-0-0 0x0 0 SP
LACP Partner Partner Partner
Port Priority Oper Key Port State
0 0x0 0x0
Eth103/1/22 0,0-0-0-0-0-0 0x0 533198 SP
0 0x0 0x0
Eth103/1/23 0,0-0-0-0-0-0 0x0 533198 SP
0 0x0 0x0
Eth103/1/24 0,0-0-0-0-0-0 0x0 533197 SP
0 0x0 0x0
01-28-2014 02:23 PM
The number of received LACPDU is 0 (103/1/21) or 60 (1/22 and 1/23) and so much less than it should be. I would resolve this issue first by either getting the server to run IEEE 802.3ad with LACP or to change the interface settings on the FEX to use channel-group 220 mode on.
If the interfaces are still changing state after correcting this we can then look to see what else it might be.
01-28-2014 02:53 PM
Steve
What I saw as I walked up to the cabinet. All four connections were lit solid. All four went out at the same time. I checked all connections to make sure they were all seated correctly, both at the cabinet and at the idf, and they were. I watched the connections at the back of the cabinet for almost 4 minutes before they all went out again. I then watched at the switches and after about a minute at that point the links went down for approx. 3 seconds then came back on all at the same time.
