Nexus 3048 vPC doesn't form
I am building up vPC on 2 x Nexus 3048 and found that it did not work properly.
The current config as follows,
1. OS: n3000-uk9.5.0.3.U2.2.bin
2. Peer link: 10 x 1G (E1/1 - E1/10) on both devices (I am wondering that 1G interface supports vPC Peer-Link. I heard that upgrading to U3.2 image will work for 1G rather than 10G... please advise me)
3. They can ping each other via management IPs
4. Edge switches vPC have not been built yet (I am focusing on Peer-Link and vPC role selection)
Device-A# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 200
Peer status                     : peer link is down
vPC keep-alive status           : peer is alive
Configuration consistency status: failed
Per-vlan consistency status     : success
Configuration consistency reason: Consistency Check Not Performed
Type-2 consistency status       : success
vPC role                        : none established
Number of vPCs configured       : 2
Peer Gateway                    : Enabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Disabled (due to peer configuration)
vPC Peer-link status
id   Port   Status Active vlans
1    Po200  down   -
vPC status
id     Port        Status Consistency Reason                     Active vlans
10     Po10        down   failed      Consistency Check Not      -
                                      Performed
20     Po20        down   failed      Consistency Check Not      -
                                      Performed
Device-A# sh run vpc
!Command: show running-config vpc
!Time: Wed Jun 13 10:49:29 2012
version 5.0(3)U2(2)
feature vpc
vpc domain 200
  role priority 100
  system-priority 4000
  peer-keepalive destination 172.23.16.68 source 172.23.16.67
  peer-gateway
  auto-recovery
interface port-channel10
  vpc 10
interface port-channel20
  vpc 20
interface port-channel200
  vpc peer-link
Device-A# sh run int port 200
!Command: show running-config interface port-channel200
!Time: Wed Jun 13 10:50:24 2012
version 5.0(3)U2(2)
  description AUULTACTABC028 vPC Peer Link
  switchport mode trunk
  vpc peer-link
  switchport trunk native vlan 55
  switchport trunk allowed vlan 28-29,43-44,55-56
  spanning-tree port type network
  negotiate auto
I am planning to upgrade to U3.2 but would like to get advice what's the best solution (currently there is no spare 10G interfaces)
Joshua
  • LAN Switching and Routing
Everyone's tags (1)
1 REPLY
Fortunately, I found the solution as upgrading to U3.(2) image.
This image supports 1G interface for Peer Link and vPC just came up without issues.
Hope this helps you those don't have enough 10G interfaces.
1140
