Nexus 3524 disabled ports
On a Nexus 3524, which of the 48 ports are enabled by default 1-24? Is there a command to list the ports that are enabled? If cables are connected to the disabled ports what will be their status?
VIP Super Bronze
try:show interface briefthis
try:
this will tell you what ports are up and what ports are down.
The command shows the
The command shows the connection status of the ports but I would like to see the license status of the ports. On a Nexus 3524 without a 48-port license only 24 of the 48 ports are enabled. Is there a command that shows the license status of the ports?
VIP Super Bronze
No, there is no command to
No, there is no command to show the license status for ports.
Hi, Please do "show license
Please do "show license usage" and check if this license below is installed. N3548-24P-UPG= .
If its just base license, only the first 24 ports will be usable.
Jay Ocampo
Hello Jay,Regarding the
Hello Jay,
Regarding the buffer space for Nexus 3524. Are all the 3 x 6MB of buffers available for the 24 ports?
Ed
624
