Webcast-Catalyst9k
NEXUS 3548 connected to WAN DEVICE (Fortigate)
                   Hei guys, a quick help.
I configured my nexus 3548 and connected to outside device which is a Fortigate. For some reason the port in switch is not coming up. I changed the speed to 1gbps. I connected laptop in switch and Fortigate seperately and found ports coming up (so not port issue).
Sh interface brief gives me reply, link not connected. Anyone faced similar issues
Hi Faisal,
What type of cable are you using?
What is the transceiver type?
Can you share the below command outputs?
show logging
show hardware int neutron-usd-uc retimer-param front-port eth x/x
Show hard int mtc-usd port-status front-port
Show interface X
Show interface x transceiver detail
Show run interface X
Show run interface X all
Show sys int ethpm info interface X
Show sys int ethpm event interface X
Richard.
Well, "no negociate auto" ?
548
