NEXUS 5000 mgmt0
pokwan
We have 2 x N5K as core/dist/access switches.  The mgmt0 int of these 2 N5k are directly connected.  I have a problem with ntp.  I cannot access the NTP server via the default VRF and I read somewhere that the access has to be via the management VRF.  With the way the mgmt 0 is connected, how can I resolve the problem with the NTP without any additional switch?
TIA
PF
12 Replies 12
Mahadev Patil
Enable vlan routing and connect your Network.
Sent from Cisco Technical Support Android App
Mahadev,
Thanks for your reply.  Can you please elaborate on your answer?  All is working except NTP.
Thanks.
PF
Hi,. Does the route to the NTP server exist in your default VRF?
Check the config guide for NTP. You need to specify where the route to the NTP server exists.
Configuring a VRF for NTP is optional. Furthermore you can use any VRF you wish.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/system_management/6x/b_5500_System_Mgmt_Config_6x/b_5500_System_Mgmt_Config_6x_chapter_010010.html
Don't forget to rate all helpful posts.
Sean,
Thanks for your reply.  I have the following configured
ntp server 192.168.1.10 use-vrf default.
The ntp resides on another site. Vrf default is where the connection to the  this site is.
Thanks.
PF
- Does the route exist to 192.168.1.0 in the default vrf?
- Can you ping the NTP server from the default vrf?
- What results do you get when you issue the debug ntp all?
- Is there a firewall in between the switch and the NTP server that could be dropping NTP packets?
Sean,
Forgot to mention that the ntp traffic is not even hitting the firewall.
Thanks.
PF
Sean,
Thanks.
Yes there is a route (default) to 192.168.1.0 on the default vrf
We can ping the NTP server from the default vrf
Below is the result from debug
TEST# debug ntp all
Terminal monitor is currently disabled on this terminal.
To observe Debugs/Syslogs, please run the command "terminal monitor"
TEST# term mon
TEST# sh debug ntp
NTP Module:
MTS Receive Packets debugging is on
MTS Transmit Packets debugging is on
MTS Receive Packet header/payload debugging is on
MTS Transmit Packet header/payload debugging is on
NTP Errors debugging is on
NTP Info debugging is on
NTP Log debugging is on
TEST# 2014 Feb 21 12:19:23.023096 ntp: Processed a sdwrap msg (MTS_OPC_DEBUG_WRAP_MSG)
2014 Feb 21 12:19:50.016424 ntp: ntp_sigchld_wait_and_fetch_status: waitpid() returns with status of 2391
2014 Feb 21 12:19:50.016494 ntp: ntp_sigchld_wait_and_fetch_status: Non-ntp child exited ! Dont care !
2014 Feb 21 12:20:19.313199 ntp: Sending Time of day upd to standby
2014 Feb 21 12:20:39 TEST last message repeated 2 times
2014 Feb 21 12:21:49.322655 ntp: Sending Time of day upd to standby
There is a firewall between the the NTP server and the switch but currently all ports are opened.
Thanks.
PF
pokwan
first you can provide tracert NTP server(N5K to NTP Server).
Mahadev,
Thanks.  We can trace all the to the NTP server via the default VRF
Thanks.
PF
Please provide tracert report...
Mahadev
pokwan
Problem resolved.  NTP bug with software version used.
Thanks all for helping.
PF
