Nexus 5010 erspan config and vlan interface
Hi there,
I'm having problems configuring an ERSPAN session on my Nexus 5010 and I'm not sure where to go next.  The ERSPAN config looks pretty straight forward ( however, when I try and use vrf management, it says this is not allowed.  I am using these as pure L2 switches, with the mgmt0 interface being my only access into the device.
So since it seems like you aren't allowed to use the management vrf for ERSPAN, I went ahead and configured a new vrf to use. I also ran an additional 1Gbps fiber link down to another device so I could have a path other than the mgmt interface. The Nexus is connected on Eth1/3 to a routed interface on a 6500.  Here's the config I'm trying to use:
vrf context NetOps
vlan 123
state active
no shut
interface Vlan123
  no shutdown
  vrf member NetOps
  ip address
interface Ethernet1/3
  switchport access vlan 123
  speed 1000
NX5K-02# sh vlan id 123
VLAN Name                             Status    Ports
123  VLAN0123                         active    Po20, Eth1/3
VLAN Type  Vlan-mode
123  enet  CE
Primary  Secondary  Type             Ports
NX5K-02# sh int vlan 123
Vlan123 is down, line protocol is down
  Hardware is EtherSVI, address is  547f.ee37.a3fc
  Internet Address is
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
NX5K-02# sh int vl123 br
Interface Secondary VLAN(Type)                    Status Reason
Vlan123   --                                      down   suspended
So I can't seem to get the vlan123 interface to come up, and as a result, my monitor session has no where to go:
NX5K-02# sh monitor session 1
   session 1
type              : erspan-source
state             : down (No route exists for configured destination ip)
erspan-id         : 100
vrf-name          : NetOps
destination-ip    :
ip-ttl            : 255
ip-dscp           : 0
origin-ip         : (global)
source intf       :
    rx            : Eth101/1/9
    tx            :
    both          :
source VLANs      :
    rx            :
Can anyone help point me in the right direction?
Thanks in advance,
Everyone's tags (2)
Community Member
This is still an issue for us
This is still an issue for us. We still do have a problem. Especially if they sit on the same vlan of the mgmt0 vrf.
