Nexus 5020 and GLC-T
Mhon Baul
Hi All,
Could someone confirm if the below nexus 5020 nx-os version and type/revision of my GLC-T is compatible with each other? I noticed also the "Transceiver calibation is invalid"  when i do show int e1/8 transceiver details , what does it mean?
UTP straight cable already plug between server and N5K but still our link is not connected.
Thanks in advance!
cheers,
mhon
8 Replies 8
Leo Laohoo
I don't remember if this is the same issue that you need a "v3" SFP to work.  Maybe I'm wrong.
Hi Leolaohoo,
thanks for your response. do you think revision 11.0 is not "v3"?
Reza Sharifi
Your version of OS does support it.  The minimum requirement is NX-OS 4.0(1a)N1(1)
have a look at table-9 in this link:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp139256
Also, have a look at this treat:
https://supportforums.cisco.com/thread/2014677
Hi Reza,
thanks for your response. Yes, I already checked this one before but I don't understand still it doesn't work
I would like to open a case but unfortunately my contract was expired and on the way to renew it..
BR,
mhon
kunkelta
I may be thinking of another switch but I believe that you need to use speed 1000 on the interface to get it to work.
hi kunkelta,  I already configured the speed on the interface
kunkelta
Another thought is that the 5020 will only do 1 Gb on certain ports. Not certain but it is the first few ports that do 1 Gb.
Yes, you are right. 5020 support 1G starting from port eth1 - eth16..
