Nexus 5500 5.1(3)N2(1) configuration stuck
I have got stuck with some config I cannot get rid of.  This is what I have (adapted to generalise it):
  port-profile type port-channel UNIX-channel
    switchport mode trunk
    switchport trunk native vlan 100
    switchport trunk allowed vlan 100, 200, 300, 400
    state enabled
  port-profile type ethernet UNIX-trunk
    state enabled
  interface Po1501
    inherit port-profile UNIX-channel
  interface Ethernet150/1/1
    inherit port-profile UNIX-trunk
    channel-group 1501 mode active
  interface Ethernet151/1/1
Now, you might think the configurations on the physical ports are ambiguous.  So the are, excpet that the port-profiles are consistent.  It works OK as it is.  But the physical links are inheriting from two different sources: the port-channel definition and the UNIX-trunk port-profile.  This is all well and good until I want to add a VLAN to the port-channel, at which point the channel definitions will be inconsistent with the port-profile.
Don't ask me how I got into this situation .... it just bseemed like a good idea at the time.  What I would like to do is to shut down each link in turn, replace the port-profile with the equivalent commands in plain text, then let the links inherit any future changes from the port-channel configuration.  But it will not let me do so.  It will not let me disinherit the port-profile, it will not let me remove the physical link from the channel group.
Bear in mind this is all in a switch-profile, because the FEX is dual-homed.  But I don't think gthat is related to the problem because I get the same reult even if I break te sync peering. Oh ... and I have to do all this on the fly without interrupting the service.
Any ideas anyone?
Kevin DORRELL
Luxembourg
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Bump?
Thanks Edison, that looks like the one, and that it affects a lot more releases than the 5.0(2) they talk about.  The problem may be more general than they admit.  I don't like their workaround ... I don't have a maintenance slot until October and I really need to use the ports now.
Thanks anyway for finding the bug.
Kevin Dorrell
Luxembourg
258
