Nexus 5500 and DCI vPC
I try to setup a DCI between two DC, each DC have two nexus 5548
DCI is supported on nexus 5500 ?
I use the vPC design, the same vPC between the two DC, the below link is for Nx 7K
http://www.cisco.com/en/US/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
I have the nexus NX1 and NX2 on DC1, NX3 and NX4 on DC2
NX1 is connected NX3 and NX2 is connected to NX2
the vpc remains down with different errors form each side :
* from DC1, the two nexus claim "vpc port channel mis-config due to vpclinks in the 2 switches connected to different partners"
* from DC2, NX3 see the  vpc ok and NX4 see it down
I can give more details if needed
thanks in advance for any information
This should be supported setup. Are you doing double site vPC? Meaning NX1 and NX3 are in one vPC domain; NX2 and NX4 are in one vPC domain. vPC domain 1 nd vPC domain 2 are connected via vPC link? What links do you have between the datacenter?
HTH,
Lei Tian
yes, you are right
a diagram:
Re: Nexus 5500 and DCI vPC
That's supported. Please refer the following document as reference.
thanks, already see this document but it talks about Nexus 7k series
any experience ?
Would you please post the configurations that you are using in the N5K devices for the links that would be connecting both DC?
In addition, would you please post the following outputs.
show vpc brief
sh vpc consistency-parameters interface ethernet x/x
Robert Rodriguez
544
