03-22-2012 06:00 PM - edited 03-07-2019 05:44 AM
..I am connecting a Nexus 5K to a 6509 without VSS. Is the recommended configuration just straight etherchannel? Since the 6509 cannot do vpc, is an etherchannel the best way to configure this uplink? How does spanning-tree operate in this scenario?
03-22-2012 06:13 PM
To take an advantage of VSS, you need to connect the Nexus to both 6500 (VSS) switches using an Etherchannel. This way you don't have to worry about spanning-tree. It is as you are connecting one switch to another.
03-22-2012 06:19 PM
We do not have VSS on our 6509's
03-22-2012 06:22 PM
I ran this scenario for a while, and there's is no way to avoid spanning-tree and achieve redundancy. We setup a vPC link from the nexus pair to each 6500, and the Nexus pair blocked towards the standby 6500.
One note of caution, make sure not to mismatch your port-channel types (LACP vs forced) in this typology. It will open up a spanning-tree loop when the LACP port fails to negotiate, does not send BPDUs, but accepts all packets recieved.
Good luck.
