Nexus 5548P and GLC-T sfpInvalid
I have a new Nexus 5548, and am trying to insert some GLC-T SFPs.
I read previous threads on here, and saw that I need to set speed 1000 before plugging in the SFPs.  So I did that.
But the SFPs still show Status sfpInvali
These are genuine Cisco SFPs, and the revision is fairly recent (P/N 30-14100-04).  Switch is running  version 5.1(3)N1(1).  Transceiver detail pasted below.  Any idea what else to check?
Tom
nexus# show int Eth1/2 transceiver details
Ethernet1/2
    transceiver is present
    type is 10Gbase-LR
    name is CISCO-FINISAR
    part number is GLC-T
    revision is VO4
    serial number is AGM1438271N
    nominal bitrate is 3200 MBit/sec
    Link length supported for 9/125um fiber is 32 km
    Link length supported for 50/125um OM3 fiber is 320 m
    Link length supported for copper is 32 m
    cisco id is --
    cisco extended id number is 4
DOM is not supported
Bump.  Any ideas?
Did you get an answer?
i am receiging the following:
SWLEN095# sh int eth 1/31 transceiver details
Ethernet1/31
    type is 1000base-T
    name is CISCO-METHODE
    part number is SP7041_Rev_F
    revision is F
    serial number is 00000MTC16140AEA
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
   Transceiver calibration is invalid
Silver
Tom
Ethernet1/2
    type is 10Gbase-LR
    revision is VO4
    cisco id is --
A GLC-T is a 1000 megabit per second copper tranciever.
Your port thinks it is a 10000 LR fibre SFP.
Are you 100% sure you've configured the port to speed 1000?
Cheers
My problem ended up being faulty SFPs.  The reseller replaced them and the new units worked fine.
4201
