01-27-2012 08:37 AM - edited 03-07-2019 04:35 AM
I have followed every piece of cisco documentation I could find on this and I still can't get vPC configured to actually work. The VLANs stay in a suspended state so no traffic flows across. Below is my configuration:
vrf context management
ip route 0.0.0.0/0 10.86.0.1
vlan 1
vlan 86
name I.S_Infrastructure
vpc domain 1
role priority 1000
peer-keepalive destination 10.86.0.4
interface Vlan1
interface Vlan86
no shutdown
description I.S._Infrastructure
ip address 10.86.0.1/24
interface port-channel1
switchport mode trunk
vpc peer-link
spanning-tree port type normal
interface Ethernet1/1
channel-group 1 mode active
interface Ethernet1/2
interface Ethernet1/3
description Connection to Mgmt0
switchport access vlan 86
speed 1000
interface mgmt0
ip address 10.86.0.3/24
Solved! Go to Solution.
01-27-2012 10:29 AM
This change this to "spanning-tree port type network"
vpc peer-link
Let me know, if that resolve your issue.
Rizwan Rafeek
01-27-2012 10:29 AM
vpc peer-link
Rizwan Rafeek
01-27-2012 10:36 AM
Still nothing. When I remove the vPC configuration and just use the port channel to trunk the vlans, both 5k's can see each other. Once I put the vPC config on I get nothing.
switch# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer link is down
(peer-keepalive not operational,
peer never alive)
vPC keep-alive status : Suspended (Destination IP not reachable)
Configuration consistency status: failed
Per-vlan consistency status : success
Configuration consistency reason: Consistency Check Not Performed
Type-2 consistency reason : Consistency Check Not Performed
vPC role : none established
Number of vPCs configured : 0
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
vPC Peer-link status
id Port Status Active vlans
1 Po1 up -
switch#
01-27-2012 11:02 AM
Assign the port-channel1 to vrf "management"
vpc peer-link
vrf memeber management
let me know.
thanks
10-23-2012 07:28 AM
Hello rizwanr74
These commands that you suggest are disruptive ? they mean any big impact inside the nexus ?
Carlos
01-27-2012 11:15 AM
I don't see the command "vrf member management" under my port channel. I do see it under mgmt0 but that had no affect on my problem.
01-29-2012 06:53 PM
Beside the peer-link is using the wrong port type (should be network). The other problem is the peer keepalive is not up:
Peer status: peer link is down (peer-keepalive not operational, peer never alive)
Can you ping 10.86.0.4 vrf management?
jerry
01-30-2012 06:40 AM
Thanks for the help everyone. Since this is new to me, I didn't know I couldn't plug the mgmt0 interface back into the 5548 and expect it to talk...So i used an external switch to provide communicaiton for mgmt0. That solved the whole problem.
01-30-2012 10:27 AM
It was good to hear that things worked out for you.
Please rate any helpful post, this might be become a helpful dip for someone else.
thanks
Rizwan Rafeek
