Community Member
Nexus 5548UP with 2248TP routing issues
Hi all,
We have a 5548UP connected to a 2248 via a 10Gb cable.  I've enabled interface-vlan, fex on top of whatever comes default out of the box.  I've also installed the L3 daughter card and installed the license for Layer 3.
On the 5548, I've created a few vlans and gave the vlan ip addresses.
vlan 10 10.10.10.1/24
vlan 20 10.10.20.1/24
vlan 30 10.10.30.1/24
On one of the ports off the 2248, I configured it as switchport access vlan 10 connected to a 2911 with an interface ip address 10.10.10.9/24
I have another port off the 2248 configured as switchport access vlan 20 with a device connected to it with an ip address of 10.10.20.10/24
There is a default route on the 5548 with 10.10.10.9 as the default gateway going to the 2911.
From the 5548 I can ping the vlan interfaces of all the vlans that I've created and all the devices connected to the 2248.  I can also ping the interface on the 2911 (10.10.10.9) and all the networks beyond the 2911 sourcing from any vlan interface.  However, all the devices off each of the vlans can not ping past its vlan interface.
Any help would be greatly appreciated.
Show ver:
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.1(3)N1(1a)
  system:    version 5.1(3)N1(1a)
  power-seq: Module 1: version v1.0
             Module 3: version v5.0
  uC:        version v1.2.0.1
  SFP uC:    Module 1: v1.0.0.0
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.1.3.N1.1a.bin
  kickstart compile time:  2/7/2012 23:00:00 [02/08/2012 07:49:30]
  system image file is:    bootflash:///n5000-uk9.5.1.3.N1.1a.bin
  system compile time:     2/7/2012 23:00:00 [02/08/2012 12:44:33]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
  Intel(R) Xeon(R) CPU         with 4118728 kB of memory.
  Processor Board ID FOC1602787D
  Device name: Nexus5548
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 6 hour(s), 54 minute(s), 52 second(s)
Last reset at 916400 usecs after  Wed May 27 20:49:29 2009
  Reason: Reset Requested by CLI command reload
  System version: 5.1(3)N1(1a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Show Lic usage:
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FC_FEATURES_PKG               No    -   Unused             -
VMFEX_FEATURE_PKG             No    -   Unused             -
ENHANCED_LAYER2_PKG           No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use Never       -
LAN_ENTERPRISE_SERVICES_PKG   No    -   Unused             -
Everyone's tags (2)
358
