Webcast-Catalyst9k
Nexus 5596 L3 SVI Interface not coming up
HI,
i have a nexus 5596 where the SIV will not come up. Some logs are as below. Any help will be appreciated.
Rgrds,
Philip.
sh ip int br
IP Interface Status for VRF "default"(1)
Interface            IP Address      Interface Status
Vlan175              10.9.175.5      protocol-down/link-down/admin-up
NXSRAGG02# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 5.2(1)N1(7)
  system:    version 5.2(1)N1(7)
  power-seq: Module 1: version v5.0
             Module 2: version v1.0
  uC:        version v1.0.0.2
  SFP uC:    Module 1: v1.1.0.0
  BIOS compile time:       05/09/2012
  kickstart image file is: bootflash:///n5000-uk9-kickstart.5.2.1.N1.7.bin
  kickstart compile time:  2/4/2014 23:00:00 [02/05/2014 08:58:28]
  system image file is:    bootflash:///n5000-uk9.5.2.1.N1.7.bin
  system compile time:     2/4/2014 23:00:00 [02/05/2014 11:27:58]
Hardware
  cisco Nexus5596 Chassis ("O2 48X10GE/Modular Supervisor")
  Intel(R) Xeon(R) CPU         with 8263828 kB of memory.
  Processor Board ID FOC17515MFL
  Device name: NXSRAGG02
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 0 hour(s), 56 minute(s), 50 second(s)
Last reset at 578014 usecs after  Wed Aug 26 08:56:11 2009
  Reason: Reset Requested by CLI command reload
  System version: 5.2(1)N1(7)
  Service:
plugin
  Core Plugin, Ethernet Plugin
NXSRAGG02# sh module
Mod Ports Module-Type                       Model                  Status
1   48    O2 48X10GE/Modular Supervisor     N5K-C5596UP-SUP        active *
2   0     O2 GEM with L3 ASIC               N55-M160L3             ok
Mod  Sw              Hw      World-Wide-Name(s) (WWN)
1    5.2(1)N1(7)     1.0     --
2    5.2(1)N1(7)     1.0     --
Mod  MAC-Address(es)                         Serial-Num
1    002a.6a9c.2408 to 002a.6a9c.2437         FOC17515MFL
2    0000.0000.0000 to 0000.0000.000f         FOC17460D18
NXSRAGG02# sh license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                No    -   Unused             -
FC_FEATURES_PKG               No    -   Unused             -
VMFEX_FEATURE_PKG             No    -   Unused             -
ENHANCED_LAYER2_PKG           No    -   Unused             -
LAN_BASE_SERVICES_PKG         Yes   -   In use Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused Never       -
Everyone's tags (1)
Hi  Not sure how you are
Not sure how you are saying the interface is not up.
Can you check the show interface status of the VLAN.
Also suggest you to have atleast a interface assigned to this VLAN
Hi Tilak, I have created the
Hi Tilak,
I have created the L2 VLAN. The outputs as follows
NXSRAGG02# sh interface vlan 175
Vlan175 is down, line protocol is down
  Hardware is EtherSVI, address is  002a.6a9c.2441
  Internet Address is 10.9.175.5/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
NXSRAGG02# sh vl br
VLAN Name                             Status    Ports
1    default                          active    Po2, Po3, Eth1/1, Eth1/2
                                                Eth1/3, Eth1/4, Eth1/5, Eth1/6
                                                Eth1/7, Eth1/8, Eth1/9, Eth1/10
                                                Eth1/14, Eth1/17, Eth1/18
                                                Eth1/19, Eth1/20, Eth1/21
                                                Eth1/22, Eth1/23, Eth1/24
                                                Eth1/25, Eth1/26, Eth1/27
                                                Eth1/28, Eth1/29, Eth1/30
                                                Eth1/31, Eth1/32, Eth1/33
                                                Eth1/34, Eth1/35, Eth1/36
                                                Eth1/37, Eth1/38, Eth1/39
                                                Eth1/40, Eth1/41, Eth1/42
                                                Eth1/43, Eth1/44, Eth1/45
                                                Eth1/46, Eth1/47, Eth1/48
175  SERVER-VLAN1                     active    Po2, Eth1/29, Eth1/30, Eth1/31
                                                Eth1/32, Eth1/45, Eth1/46
                                                Eth1/47, Eth1/48
176  SERVER-VLAN2                     active    Po2, Eth1/29, Eth1/30, Eth1/31
                                                Eth1/47, Eth1/48
200  Management                       active    Po2, Eth1/29, Eth1/30, Eth1/31
                                                Eth1/47, Eth1/48
Hi Tilak,It is okay now. The
Hi Tilak,
It is okay now. The peer link was not configured as a trunk. That is why it wasnt coming up.
Thanks & Regards,
Philip.
 Hi PhilipGood to know !!
Hi Philip
Good to know !!
497
