07-19-2013 09:48 AM - edited 03-07-2019 02:29 PM
I have a nexus 5596 and I am wondering if anyone knows why they decided to make it back to front air flow. Also I have installed it in a cabinet and it is blowing into the cold aisle. I have most of the ports filled and am wondering if there are any options to reverse the airflow.
Also, does anyone know how cisco intended these to be installed and have 48 cables connected with the back to front air flow?
Any help will be appreciated.
Solved! Go to Solution.
07-19-2013 09:58 AM
For the 5k series you can do front to back and back to front:
Airflow Direction
The airflow through the fan trays and power supplies on the Cisco Nexus 5548 UP switch is either from front to back or from back to front, depending on how the modules were ordered. The airflow through the other Cisco Nexus 5000 Series switches is from front to back. To ensure proper airflow, you must make sure that when you install the switch its air intake is positioned in a cold aisle and the air exhaust is positioned in a hot aisle for your data center.
It should be installed with ports facing on the same side where your server ports are located.
07-19-2013 10:58 AM
I have only used 5548UP and it is front to back. And yes, you can change your to be front to back.
07-19-2013 11:40 AM
Yes, here is the part number for tha fan
N5548P-FAN(=) | Cisco Nexus 5548P/5548UP Fan Module, Front-to-Back Airflow, Spare |
see table-11 for fan and power supply part numbers
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
07-19-2013 09:58 AM
Airflow Direction
07-19-2013 10:11 AM
If I already have the back to front model can I change them to front to back with replacement fans?
I have the ports facing the correct side but I have the wrong air flow model. Also I have the 5596UP. Is the model number you used 5548 UP the front to back?
07-19-2013 10:58 AM
07-19-2013 11:18 AM
Thank you for your help.
Do you know if I need to replace the fans and power supplies?
07-19-2013 11:40 AM
07-19-2013 01:57 PM
Thank you. You're Awesome.
07-19-2013 02:07 PM
Glad to help David,
Thanks for the rating!
