Community Member
Nexus 5596UP and GLC-SX-MM SFP
I'm trying to get my GLC-SX-MM sfp (1gb fiber multi-mode) working in my Nexus 5596UP.
All my other sfp are working fine like the GLC-T (1000BASE-T copper).
With the copper spf, all I have to do is to set the speed manually and it become active.
But my fiber 1gb sfp aren't working even if I set the speed.
Eth1/40       --                 sfpInvali 1         full    1000    1/10g
Ethernet1/40
    transceiver is present
    type is 1000base-SX
    name is CISCO-INTEL
    part number is TXN311100000001
    revision is --
    serial number is ICF094720JD
    nominal bitrate is 2100 MBit/sec
    Link length supported for 50/125um fiber is 550 m
    Link length supported for 62.5/125um fiber is 270 m
    cisco id is --
    cisco extended id number is 4
I tried several sfp in differents ports but it just doesn't work.
Anyone has succesfully used them in nexus ??
Thank you and sorry for my english
Community Member
Re: Nexus 5596UP and GLC-SX-MM SFP
I sucessfully actived one of my sfp.
It working with some and not working with other.
The difference ?
Working sfp :
Ethernet1/40
    type is 1000base-SX
    name is CISCO-AGILENT
    part number is QFBR-5766LP
    revision is
    serial number is AGS094851VK
    nominal bitrate is 1300 MBit/sec
    cisco id is --
None working sfp :
Ethernet1/40
    type is 1000base-SX
    name is CISCO-INTEL
    revision is --
    cisco id is --
so Cisco-Agilent models works and Cisco-Intel don't....wow
I'm begining to think that the one not working is fake/counterfeit gbic....
You an use following configuration guide link:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/layer2/503_n1_1/Cisco_n5k_layer2_config_gd_rel_503_N1_1_chapter3.html#task_A6C551C739324293B020FD7C35F018D0
This example shows how to configure a unified port on a Cisco Nexus
5548UP switch or Cisco Nexus 5596UP switch:
switch# configure terminal
switch(config)# slot 1
switch(config-slot)# port 32 type fc
switch(config-slot)# copy running-config startup-config
switch(config-slot)# reload
Please note: Fibre Channel ports must be configured from the last port
of the module.
3832
