Community Member
NEXUS 56128 and FEX with beakout cable
using two NEXUS 56128 , I wish to create enhanced VPC architecture with FEX 2248TP.
My question is : can I use 40Gbs ports on NX56128 with QSFP breakout DAC cable (40G to 4x10G) to connect FEX 2248 ?
regards
Community Member
Hi Yallies,For the Nexus
Hi Yallies,
For the Nexus 56128 (http://cs.co/9002c2aC) , it supports 8 true 40 GE QSFP ports and up to 96 10GE ports ( of which 48 are UP). Since the Nexus 5600 supports high density fabric extender aggregation platform, they can be used with the Nexus 2248PQ, 2248TP. Feel free to message me directly for further assistance. Hope this helps! :)
Angela (ageralde@cisco.com)
Community Member
Hi, since it is possible to
since it is possible to connect a FEX (2248PQ) with one native 4GE Port via breakout cable to N56128.
Is there any additional configuration required or does the 40GE breakout cable force the port to 4x10GE?
thanks
Udo
Community Member
On my 6001's I had to run
On my 6001's I had to run interface breakout, then they went from 2/1 to 2/1/1-4
interface breakout slot 2 port 1-2 map 10g-4x
Mike
584
