10-12-2013 08:00 AM - edited 03-07-2019 04:00 PM
I am trying to upgrade Nexus 5596 out of box, have assigned IP address to management interface & default route under management VRF, not able to ping management interface from within nexus, what is needed to make it work ?
Will TFTP work for downloading software ?
thanks
hasrat
Solved! Go to Solution.
10-12-2013 11:34 AM
Hi Hasrat,
1. I understood that you configured in right way, let me share the detail again for reconfirmation.
To configure the management (mgmt0) Ethernet interface to connect over IP, perform this task:
Please try to ping the management like below command,
#ping
Example:
Nexus# ping 10.104.149.1 vrf management
PING 10.104.149.1 (10.104.149.1): 56 data bytes
64 bytes from 10.104.149.1: icmp_seq=0 ttl=254 time=1.441 ms
64 bytes from 10.104.149.1: icmp_seq=1 ttl=254 time=1.082 ms
64 bytes from 10.104.149.1: icmp_seq=2 ttl=254 time=0.964 ms
64 bytes from 10.104.149.1: icmp_seq=3 ttl=254 time=0.945 ms
64 bytes from 10.104.149.1: icmp_seq=4 ttl=254 time=0.955 ms
--- 10.104.149.1 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.945/1.077/1.441 ms
Refer:
You can use ftp:, tftp:, scp:, or sftp: to download the Nexus OS on the switch.
1. Select and download the kickstart and system software files to a server.
2. Ensure that the required space is available in the bootflash: directory for the image file(s) to be copied.
3. If you need more space on the active supervisor module bootflash, delete unnecessary files to make space available.
4. Copy the kickstart and system images to the supervisor module bootflash with a transfer protocol.
switch# copy
scp://user@scpserver.cisco.com//downloads/n5000-uk9-kickstart.4.0.0.N1.2.bin
bootflash:n5000-uk9-kickstart.4.0.0.N1.2.bin
switch# copy
scp://user@scpserver.cisco.com//downloads/n5000-uk9.4.0.0.N1.2.bin
bootflash:n5000-uk9.4.0.0.N1.2.bin
5. Install the new images, specifying the new image names that you downloaded in Step 9.
switch(config)# install all kickstart
bootflash:n5000-uk9-kickstart.4.0.0.N1.2.bin system
Refer:
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b4b9dd.shtml
Aru
*** Pleaes rate if the post is useful ***
10-12-2013 11:34 AM
Hi Hasrat,
#ping
Example:
Refer:
switch# copy
switch# copy
Refer:
Aru
10-12-2013 12:15 PM
Hi Aru,
Thank you for the response, I'll check & inform.
Thanks Again
10-16-2013 08:48 AM
Thank you Aru, it worked.
hasrat
