Nexus 5696 NX-OS uprade
I am trying to upgrade Nexus 5596 out of box, have assigned IP address to management interface & default route under management VRF, not able to ping management interface from within nexus, what is needed to make it work ?
Will TFTP work for downloading software ?
thanks
hasrat
1 ACCEPTED SOLUTION
Hi Hasrat,
1. I understood that you configured in right way, let me share the detail again for reconfirmation.
Configuring the Management Interface
To configure the management (mgmt0) Ethernet interface to connect over IP, perform this task:
Command
Purpose
Step 1
switch# configure terminal
Enters configuration mode.
Step 2
switch(config)# interface mgmt 0
Selects the management Ethernet interface on the switch and enters interface configuration submode.
Step 3
switch(config-if)# ip address ipv4-address[/length]
Configures the IPv4 address and its subnet mask.
switch(config-if)# ip address ipv4-address [subnet-mask]
An alternative method that configures the IPv4 address and its subnet mask.
switch(config-if)# ipv6 address ipv6-address[/length]
Configures the IPv6 address and its subnet mask.
Step 4
switch(config-if)# no shutdown
Enables the interface.
Step 5
switch(config-if)# exit
Returns to configuration mode.
Step 6
switch(config)# vrf context  management
Enters VRF context management configuration mode.
Step 7
switch(config-vrf)# ip route ipv4-prefix[/length]  ipv4-nexthop-address
Configures the IPv4 address of the next hop.
switch(config-vrf)# ipv6 route ipv6-prefix[/length]  ipv6-nexthop-address
Configures the IPv6 address of the next hop.
Step 8
switch(config-vrf)# exit
Returns to EXEC mode.
Step 9
switch# copy running-config  startup-config
(Optional) Saves your configuration changes to the file system.
Please try to ping the management like below command,
#ping vrf management
Example:
Nexus# ping 10.104.149.1 vrf management
PING 10.104.149.1 (10.104.149.1): 56 data bytes
64 bytes from 10.104.149.1: icmp_seq=0 ttl=254 time=1.441 ms
64 bytes from 10.104.149.1: icmp_seq=1 ttl=254 time=1.082 ms
64 bytes from 10.104.149.1: icmp_seq=2 ttl=254 time=0.964 ms
64 bytes from 10.104.149.1: icmp_seq=3 ttl=254 time=0.945 ms
64 bytes from 10.104.149.1: icmp_seq=4 ttl=254 time=0.955 ms
--- 10.104.149.1 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.945/1.077/1.441 ms
Refer:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/initconfig.html#wp1110654
You can use ftp:, tftp:, scp:, or sftp: to download the Nexus OS on the switch.
1. Select and download the kickstart and system software files to a             server.
2. Ensure that the required space is available in the bootflash:             directory for the image file(s) to be copied.
3. If you need more space on the active supervisor module bootflash,             delete unnecessary files to make space available.
4. Copy the kickstart and system images to the supervisor module             bootflash with a transfer protocol.
switch# copy
        scp://user@scpserver.cisco.com//downloads/n5000-uk9-kickstart.4.0.0.N1.2.bin
        bootflash:n5000-uk9-kickstart.4.0.0.N1.2.bin
switch# copy
        scp://user@scpserver.cisco.com//downloads/n5000-uk9.4.0.0.N1.2.bin
        bootflash:n5000-uk9.4.0.0.N1.2.bin
5. Install the new images, specifying the new image names that you downloaded in Step 9.
    switch(config)# install all kickstart
            bootflash:n5000-uk9-kickstart.4.0.0.N1.2.bin system
Refer:
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b4b9dd.shtml
Aru
*** Pleaes rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Hi Hasrat,
Command
Purpose
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Example:
Refer:
switch# copy
switch# copy
Refer:
Aru
Hi Aru,
Thank you for the response, I'll check & inform.
Thanks Again
Thank you Aru, it worked.
hasrat
312
