Nexus 5K Peer Link Not Coming Up
Would a difference in the network QoS cause the vPC not to come up? As you can see below, the Network QoS (MTU) are different. If so, how do I change these values?
Thank Yougfvvv
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
QoS                         2     ([], [3], [], [], [],  -
Network QoS (MTU)           2     (1538, 2196, 0, 0, 0,  -
                                  0)
   Legend:
QoS                         2     ([], [], [], [], [],   -
Network QoS (MTU)           2     (1538, 0, 0, 0, 0, 0)  -
Network Qos (Pause)         2     (F, F, F, F, F, F)     -
Everyone's tags (1)
Purple
  It will usually tell you in the logg buffer the reason why it was suspending .  Also the command show vpc consistency parameters will show you what it checks and I believe it will show you both sides of the link.
N5K-1
Input Queuing (Bandwidth)   2     (100, 0, 0, 0, 0, 0)   -
Input Queuing (Absolute     2     (F, F, F, F, F, F)     -
Priority)
Output Queuing (Bandwidth)  2     (100, 0, 0, 0, 0, 0)   -
Output Queuing (Absolute    2     (F, F, F, F, F, F)     -
Priority)
STP Mode                    1     Rapid-PVST             -
STP Disabled                1     None                   -
STP MST Region Name         1     ""                     -
STP MST Region Revision     1     0                      -
STP MST Region Instance to  1                            -
VLAN Mapping
STP Loopguard               1     Disabled               -
STP Bridge Assurance        1     Enabled                -
STP Port Type, Edge         1     Normal, Disabled,      -
BPDUFilter, Edge BPDUGuard        Disabled
STP MST Simulate PVST       1     Enabled                -
Allowed VLANs               -     -                      -
Local suspended VLANs       -     -                      -
N5K-2
                                  0)
Network Qos (Pause)         2     (F, T, F, F, F, F)     -
Input Queuing (Bandwidth)   2     (50, 50, 0, 0, 0, 0)   -
Priority)
Output Queuing (Bandwidth)  2     (50, 50, 0, 0, 0, 0)   -
Priority)
VLAN Mapping
Allowed VLANs               -     -                      -
ho vpc br
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer link is down
vPC keep-alive status             : peer is alive
Configuration consistency status  : failed
Per-vlan consistency status       : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason       : Consistency Check Not Performed
vPC role                          : none established
Number of vPCs configured         : 0
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Disabled (due to peer configuration)
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    down   -
VIP Super Bronze
The peer link between the switches are down.
Can you post "sh run" from both switches and tell us what ports are used as peer links?
Also, is vPC keep alive configured on both switches?
vPC keep-alive is configured as the mgmt interface.....
ports 1/1 and 1/2 are being used as the peer links.....
Re: Nexus 5K Peer Link Not Coming Up
Terry,
I take it as you are using the mgmt infterfaces you have them set up something like ..........
interface mgmt0
ip access-group MGMT-IN in
ip address 1.1.1.2/24
and the vpc domain configured something like...............
"peer-keepalive destination 1.1.1.1 source 1.1.1.2"
and vice-versa on the other switch?
Keith
317
