Nexus 5K unable to add syslog server.
Siddharam M
Hi ,
I am trying to configure syslog server ip address on my nexus 5k. I was able to add 1 syslog server ip but when i am trying to add another i am getting error like "session currently owned by a different user" and i am unable to add it.
any help would be appriciated.
Attaching the screenshot.
-- Siddu
Reza Sharifi
What version of Nexus-OS are you running?
 kickstart: version 4.2(1)N2(1a)
 system:    version 4.2(1)N2(1a)
--Siddu
Appears to be a bug in the code that is fixed in later versions (5.2x and 6.0 version)
Here is link with similar issue but related to TACACS.
https://supportforums.cisco.com/discussion/11056521/nexus-5000-config-sync-and-tacacs-problem-switch-profile
