06-04-2010 09:06 AM - edited 03-06-2019 11:25 AM
Hi All:
I just want to confirm I understand the VPC Peer-Link correctly. We have 2 6509 VSS as cores and 2 N5K's using VPC. If 2 servers were single connected to the N5k on an "orphaned" port (one server on each 5k), how will this traffic flow between the two servers? From what I understand, this traffic flow would be sent through the 6509's. It would not normally traverse the 5k peer-link, correct? If we wanted the traffic to flow directly between the 2 N5k's, we would need to setup a seperate physical trunk between the 2 N5k's?
Patrick
06-04-2010 10:38 AM
This will most likely work but is not a cisco recommended design and if you did run into a forwarding problem speciffic to this scenario it's not 100% that the developers would consider it supported and fix the bug. If this was a 7K there would be a few additional gotchas that would make it an even worse idea. On a 5K you can likely get away with it but the short answer is don't do it.
-Ben
06-07-2010 08:18 AM
Thanks for the confirmation. I definately don't want to setup a seperate direct connection between the N5K for data traffic. Like, you said, there are a host of caveats that will pop up.
Patrick
