Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Nexus 7000 : Configuring Jumbo MTU
I have a Nexus 7000 plus 6 boxes NX2000 on backbone.
I have configured on 7000 :
conf t
system jumbomtu 9000
exit
ERROR: Ethernet111/1/1: requested config change not allowed
ERROR: Ethernet122/1/48: requested config change not allowed
1/111/14 is a NX2000 port
conf t
interface ethernet 1/111/14
switchport
mtu 9000
exit
I have gotten this message :
Error: MTU cannot be configured on satellite port(s) - Eth122/1/11
I have tried on a NX7000 TP port:
ERROR: Ethernet10/45: MTU on L2 interfaces can only be set to default or system-jumboMTU
Does JUMBOMTU configuration can be done only when there are no NX2000 configured ?
Rosa
1 REPLY
On the N7K FEX inherit the MTU of their parent interface so
by configuring it on the parent interface all FEX ports will support jumbos.
You won’t be able to configure a jumbo MTU under a FEX interface as it’ll
give you an error message.
The sample you have below is a Nexus 5000 policy to enable jumbo frame
support.
See below:
interface port-channel150
switchport
switchport mode fex-fabric
fex associate 150
mtu 9216
cmhlab-dc2-sw2-agg1# show int e150/1/48
Ethernet150/1/48 is down (Administratively down)
Hardware: 100/1000 Ethernet, address: 588d.0915.9df1 (bia 588d.0915.9df1)
MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec
Here’s the error message
cmhlab-dc2-sw2-agg1# confi t
Enter configuration commands, one per line.  End with CNTL/Z.
cmhlab-dc2-sw2-agg1(config)# int e150/1/48
cmhlab-dc2-sw2-agg1(config-if)# mtu 4000
Error: MTU cannot be configured on L2 satellite port(s) - Eth150/1/48
So you can configure that on FEX port-channel.
Hope this helps,
Nik
6591
