07-07-2015 01:56 AM - edited 03-08-2019 12:51 AM
Hi everyone,
While polling the host using snmpwalk and 1.3.6.1.2.1.47.1.1.1.1.7 OID got nothing interesting. But I need to get this info somehow:
show interface ethernet 3/46 transceiver details
Ethernet3/46
transceiver is present
type is 10Gbase-ER
name is CISCO-OPNEXT,INC
part number is TRS7050EN-S103
revision is 0012
serial number is ONT173604QB
nominal bitrate is 10300 MBit/sec
Link length supported for 9/125um fiber is 40 km
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 33.15 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.30 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 46.98 mA 120.00 mA 20.00 mA 112.00 mA 24.00 mA
Tx Power 0.67 dBm 6.99 dBm -8.72 dBm 3.99 dBm -4.71 dBm
Rx Power -17.69 dBm - 1.99 dBm -20.00 dBm -1.00 dBm -15.85 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
*** SFP diagnostics data may be invalid! ***
Could you guys point me out regarding the right SNMP OID?
Thanks!
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2013, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
BIOS: version 2.12.0
kickstart: version 6.1(4a)
system: version 6.1(4a)
BIOS compile time: 05/29/2013
kickstart image file is: bootflash:///n7000-s2-kickstart-npe.6.1.4a.bin
kickstart compile time: 12/25/2020 12:00:00 [09/26/2013 06:22:01]
system image file is: bootflash:///n7000-s2-dk9-npe.6.1.4a.bin
system compile time: 7/8/2013 19:00:00 [09/26/2013 08:08:40]
Hardware
cisco Nexus7000 C7004 (4 Slot) Chassis ("Supervisor module-2")
Intel(R) Xeon(R) CPU with 12225160 kB of memory.
07-08-2015 07:03 AM
Just guessing may be NX-OS 6.1(4a) doesnt support this feature ( get transceiver TX/RX Power data via SNMP)? Catalyst C3750 switches for instance do that with no problem btw.
07-08-2015 08:36 AM
snmpwalk -c XXXXX -v2c XX.XX.XX.XX 1.3.6.1.2.1.47.1.1.1.1.7
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
Cannot find module (UCD-SNMP-MIB): At line 0 in (none)
Cannot find module (UCD-DEMO-MIB): At line 0 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 0 in (none)
Cannot find module (NET-SNMP-AGENT-MIB): At line 0 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (UCD-DLMOD-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 0 in (none)
Cannot find module (SNMPv2-TM): At line 0 in (none)
iso.3.6.1.2.1.47.1.1.1.1.7.10 = STRING: "Fabric Stack Root"
iso.3.6.1.2.1.47.1.1.1.1.7.22 = STRING: "Supervisor module-2"
iso.3.6.1.2.1.47.1.1.1.1.7.23 = STRING: "Supervisor module-2"
Is it OK for snmpwalk to ignor the 'Cannot find module' error?
08-17-2015 09:26 AM
Bug CSCty93934
Description
Symptom:
Nexus does not have entityPhysical Indexes for a slot/port combination which can be used to query entitySensorValue/entityThreshold values.
This leads to inability to retrieve DOM statistics from SFP transceivers in easy way.
