Nexus 7000 Version 6.0(1) QoS Question
Hello Team,
Could you please provide a little bit of guidance on QoS on Nexus switches running version 6.0(1)? I have been looking for QoS SRND for Nexus, but I have not found it, and I don't think there is one available. That being said, I have been researching and reading as much documentation as possible in order to match the QoS class/policy configuration on two Nexus 7000 switches I am configuring for one of my clients. I have learned that on 6.0(1) the "class-map type queuing" command was removed also discovered that class-map type network-qos is only supported on the default VDC. That being said, I have built the class maps with qos type, but when I am trying to apply the queue-limit commands the "class type qos" does not support it. Please see below for the configuration I built. I don't think it's going to work because the class maps were defined as qos as it was the only option available and the class type under the policy-map were defined as queuing. Are there any recommendations you could provide? Any help is greatly appreciated.
class-map type qos match-any 1p7q4t-out-q2
  match cos 7
class-map type qos match-any 1p7q4t-out-q3
  match cos 6
class-map type qos match-any 1p7q4t-out-q4
  match cos 3
class-map type qos match-any 1p7q4t-out-q5
  match cos 2
class-map type qos match-any 1p7q4t-out-q6
  match cos 4
class-map type qos match-any 1p7q4t-out-q7
  match cos 0
class-map type qos match-any 1p7q4t-out-pq1
  match cos 5
class-map type qos match-any 1p7q4t-out-q-default
  match cos 1
policy-map type queuing TEN_GIG-QUEUE-OUT
  class type queuing 1p7q4t-out-pq1
    priority level 1
    queue-limit percent 30
  class type queuing 1p7q4t-out-q2
    random-detect cos-based
    random-detect cos 7 minimum-threshold percent 80 maximum-threshold percent 1
00
    bandwidth remaining percent 5
    queue-limit percent 5
  class type queuing 1p7q4t-out-q3
    random-detect cos 6 minimum-threshold percent 80 maximum-threshold percent 1
00
  class type queuing 1p7q4t-out-q4
    random-detect cos 3 minimum-threshold percent 80 maximum-threshold percent 1
00
    bandwidth remaining percent 20
    queue-limit percent 10
  class type queuing 1p7q4t-out-q5
    random-detect cos 2 minimum-threshold percent 80 maximum-threshold percent 1
00
  class type queuing 1p7q4t-out-q6
    random-detect cos 4 minimum-threshold percent 80 maximum-threshold percent 1
00
  class type queuing 1p7q4t-out-q7
    random-detect cos 0 minimum-threshold percent 80 maximum-threshold percent 1
00
    bandwidth remaining percent 25
    queue-limit percent 25
  class type queuing 1p7q4t-out-q-default
    random-detect cos 1 minimum-threshold percent 80 maximum-threshold percent 1
00
  match cos 7
  match cos 6
  match cos 3
  match cos 2
  match cos 4
  match cos 0
  match cos 5
  match cos 1
    priority level 1
00
00
00
00
00
00
00
302
