Community Member
nexus 7000 vPC
If I have two VDC on each nx7000
How many cables I need to connect them all ?
I heard one pair(two physical link) for each VDC ?!?
So I will need four physical dedicate links ?!
Johnson
Hall of Fame Super Silver
Re: nexus 7000 vPC
Hello Johnson,
the following can be a good starting point
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/C07-572831-00_Dsgn_Nexus_vPC_DG.pdf
Hope to help
Giuseppe
Re: nexus 7000 vPC
Johnson
Hi Johnson,
A  virtual port channel (vPC) allows links that are physically connected to two different Cisco Nexus 7000 Series devices to appear as a single port channel by a third device and the third device can be a switch, server, or any other networking device that supports port channels.
Check out the below link on cisco nexus 7000 series Hope that helps
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_1/nx-os/interfaces/configuration/guide/if_vPC.html
Ganesh.H
Community Member
Re: nexus 7000 vPC
You are correct. This was a tough gotcha in a customer scenario we ran into. Each VDC requires a physical connect when you want them connected, no matter if its on the same chassis or not. There was no virtual ability to make this connection at this time. Each VDC has to be treated like a physically seperate switch when it comes to interconnects. This is important to keep in mind when adding VDC's, especially when we look at doing a Core/Distribution VDC on redundant 7ks'.
Community Member
Re: nexus 7000 vPC
Also the recommendation with vPC's is 2 links across 2 blades for redundancy since the crossconnect with vPC's is so critical.
1153
