Webcast-Catalyst9k
Nexus 7009 to 7004 VPC
Dear All,
Our Customer's configuration below mentioned;
  • N7K-C7009
  • SUP2 x 2
  • 5 x Fabric2 Module
  • 1x 48 Port F2E SFP+ Card
  • 6x 48 Port M1 10/100/1000 Cooper Card
  • Firmware : 6.2.x
Our Customer wants to purchase below products ;
  • N7K-C7004
  • SUP2 x2
  • 1x 48 Port M1 10/100/1000 Cooper Card
  • Firmware : 6.2.x
He wants to use two configs together with VPC. Is it possible to work like that ?
Thanks in advance.
Everyone's tags (3)
What do you mean use two configs together? What are you trying to accomplish?
hello,
i mean,
that we can use two configuration which one is customer's has configuration and the other is want to purchase.
we want to use all products eachother by using vPC. i dont know is it working,
VIP Super Bronze
Yes, that will work fine.  You don't have to have the exam same models to do vPC.  You can use a 7009 with a 7004
or 7010 and 7004.
Dear Reza,
what do you mean the i dont' have to have the exam same models to do vPC ?
cant i use 7009 with 7009 or 7010 with 7010 ?
i will use 7009 with 7004, is it working?
thank you.
VIP Super Bronze
yes
yes it will work.
Dear Reza,
isn't it a silly for you as well i really dont understand how the same models cannot work with together by vPC.
i thought you were kidding..
do you have any documents about that ?
VIP Super Bronze
What I saying is that the same model works and even if they are not the same model it still works.
296
