Nexus 7010 error port
budi-afianto
I use Nexus 7010 on my client.
There is using 48port ethernet module as I/O on slot 1 and 2 and then I add new module 48port ethernet module on slot 7 and 8.
Some port already use for connection to server (end device) on slot 1 and 2. At this time, nexus work properly and I can use unused port, configure it to connected to server.
But after several month, when I want to use the unused port (port that not connected to end device/server), I had problem that every unused can not be used. I used command sh interface on that port and get no trafic that send from this port (Tx zero).
*all used port that already connceted to server work properly.
Simple topology for testing:
Nexus port eth1/5     --------------------------               PC
10.10.10.1/24              connected to          10.10.10.2/24
nexus:
int eth1/5
no switchport
ip add 10.10.10.1 255.255.255.0
no shut
PC:
ip add 10.10.10.2
subnet mask 255.255.255.0
gateway: 10.10.10.1
from this scenario I can't ping from PC to nexus or Nexus to PC. (nexus port status is connected routed and led status green)
I would appreciate it if anyone has same problem and can tell me to solve this problem.
9 Replies 9
viswamin
can you please share the output of show interface eth1/5
-Vijay
darren.g
Level 5
Level 5
nexus:
int eth1/5
no switchport
no shut
PC:
ip add 10.10.10.2
gateway: 10.10.10.1
Without knowing more information about your Nexus config, it's impossible to tell.
Can you post the output from the following commands
show run int e1/15
show run int e1/?? <- pick one of your working server-connected interfaces
show int e1/15
Alternately, post a sanitised (passwords removed etc) copy of your entire Nexus config.
Cheers.
Thank for your respons guys..
I am so sory, but I have not full authorization access to get sh run for the device. I only have this note:
sh int status:
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/5        --                 connected routed        full    1000    10/100/1000
sh run int eth1/5:
int eth1/5
no switchport
no shut
sh int status:
sh run int eth1/5:
int eth1/5
no switchport
no shut
Is the PC a Windows box with the firewall enabled, by any chance? The default Windows firewall installation denies PING traffic. From what you've posted I can't see anything which could be causing this not to work.
Cheers.
Why is there "no switchport" in int eth1/5?
If the port is for a Server you should configure it as a switchport.
Thomas
"no switchport" is configured to make the interface routed and to be able to assign an ip address
Darren
Without more information we can only gues possible reasons:
1. configuration issue
2. server issue
3. link issue
can you gater more info from the box:
try to ping from n7k your server using e1/5 as a source address
sh mod
sh int e1/5
sh int e 1/5 counters
sh run int e 1/5
Alex
I have solve this problem by Upgrade NX-OS, from
n7000-s1-kickstart.5.1.3.bin to n7000-s1-kickstart.5.0.2a.bin
n7000-s1-dk9.5.1.3.bin ton7000-s1-dk9.5.0.2a.bin
I think this just bugs, maybe because I add new module 48port ethernet module on slot 7 and 8.
Thanks fo support..
Hi Budi
That was downgrade as 5.0.2a is older that 5.1.3
Probably Feature that contained the bug hasn't been realised in the 5.0.2a version so the bug is also not present.
Alex
Sory Alex,
I make mistake when I write, it should be
n7000-s1-kickstart.5.0.2a.bin    to     n7000-s1-kickstart.5.1.3.bin
n7000-s1-dk9.5.0.2a.bin     to    n7000-s1-dk9.5.1.3.bin
So it is upgrade not downgrade.
This is capture running NX-OS at nexus
Software
  BIOS:      version 3.22.0
  kickstart: version 5.1(3)
  system:    version 5.1(3)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.5.1.3.bin
  kickstart compile time:  12/25/2020 12:00:00 [03/11/2011 14:42:56]
  system image file is:    bootflash:///n7000-s1-dk9.5.1.3.bin
  system compile time:     1/21/2011 19:00:00 [03/11/2011 15:37:35]
