Nexus 7010 unable to ping within vlan
Yesterday I configured the 7010 Nexus switch. I created a VDC and allocated few ports and configured VLAN for testing. After enabling feature interface-​vlan i was allowed to configured L3 interface for the vlan. I assigned ip address and connected few server to check the reachability but it says Destination Host Unreachable.
NX OS Ver : n7000-s1-dk9.5.2.4.bin
Configuration of the VDC below. Please let me know if i am missing some configuration
feature telnet
feature udld
feature interface-vlan
feature lacp
vrf context management
  ip route 0.0.0.0/0 10.95.253.193
vlan configuration 704
vlan 1,704
interface Vlan704
  no shutdown
  ip address 10.84.254.193/26
interface Ethernet2/5
    switchport
  switchport mode access
  switchport access vlan 704
  no shutdown
interface Ethernet8/48
  switchport
  no shutdown
switch-DLACC# sh ip int brief
IP Interface Status for VRF "default"(1)
Interface            IP Address      Interface Status
Vlan704              10.84.254.193   protocol-up/link-up/admin-up
switch-DLACC# sh ip route
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
10.84.254.192/26, ubest/mbest: 1/0, attached
    *via 10.84.254.193, Vlan704, [0/0], 09:30:07, direct
10.84.254.193/32, ubest/mbest: 1/0, attached
    *via 10.84.254.193, Vlan704, [0/0], 09:30:07, local
switch-DLACC#
switch-DLACC# ping  10.84.254.202
PING 10.84.254.202 (10.84.254.202): 56 data bytes
36 bytes from 10.84.254.193: Destination Host Unreachable
Request 0 timed out
^C
--- 10.84.254.202 ping statistics ---
2 packets transmitted, 0 packets received, 100.00% packet loss switch-DLACC#ping  10.84.254.202
Request 0 timed out
^C
switch-DLACC# sh module
Mod  Ports  Module-Type                         Model              Status
1    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
2    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
3    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
4    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
5    0      Supervisor module-1X                N7K-SUP1           active *
6    0      Supervisor module-1X                N7K-SUP1           ha-standby
7    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
8    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
9    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
10   32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
Everyone's tags (1)
Hi Uvaraj,
Can you provide a diagram of the topology so I can attempt to help? Are the servers directly attached to the Nexus or is there additional equipment in between them?
Anthony
Hi Uvaraj
which ip connected to Ethernet8/48
Please add
sh int eth 8/48
sh ip arp
sh mac add inter eth 8/48
Alex
1526
