Webcast-Catalyst9k
Nexus 7010 upgrade
due to CTS bug, i need to upgrade Nexus 7010 from NX-OS 4.2(6) to 6.0(1) ... small jump :-)
But i don't know what is the best way. I know that i need to do EPLD upgrade and make ISSU upgrade from 4.2(6) to 5.2(1), and 5.2(1) to 6.0(1)
Can i do the 2 NX-OS upgrade and after the EPLD upgrade ? 1 NX-OS upgrade , EPLD and after the second NX-OS upgrade ?
Ohter question, What about the EPLD upgrade when i upgrade the M132XP-12, all the VPC-Peer link are on this line card. It is a problem ?
Thanks for your help.
Michaël
Everyone's tags (1)
1 REPLY
Nexus 7010 upgrade
Are you sure you want to jump to 6.0(1)? If you are not using F2, you can stay on the NXOS 5.2 instead. X.2 is what we called long live release:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps9494/ps9372/guide_c07-658595.html
You should upgrade the NXOS software before performing EPLD upgrade (if this is 100% required).
For your single M132 line card, the following remediation should be configured before upgrade. If not, you will cause an outage on the vPC secondary switch when you lost the peer-link:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/interfaces/configuration/guide/if_vPC.html#wp1558824
HTH,
jerry
900
