Community Member
Nexus 7010 VSS
Does the nexus 7010 support virtual switching yet??  All of the posts I have found from about a year ago say that it is going to be supported, but there were no dates listed.     I heard the same thing from Cisco a while back, but haven't followed up with it.
If it is supported finally are there any configuration guides available for it?
VIP Super Bronze
Re: Nexus 7010 VSS
Currently VSS is only supported on the 6500 series.
Reza
Community Member
Re: Nexus 7010 VSS
Is this absolutely true? I have been researching and noticed this thread but would like verification on this.
Community Member
Re: Nexus 7010 VSS
It is true.  I just came back fromt a Nexus briefing and Cisco stated that they don't support VSS on Nexus as today.  However, they support VDC on Nexus.  So instead of stacking two boxes into one virtual box like what VSS does, VDC creates small virtual switches (currently 4, roadmap to 8) within N7K.
Community Member
Re: Nexus 7010 VSS
ok thanks for the clarification!!!
Ben Sullivan
x44375
Network Engineering
Information Technology, Princess Cruises
"kevin.hu"
DAT
04/13/2010 08:25 AM
Please respond to
"cisco-support@sgaur.hosted.jivesoftware.com"
To
Ben Sullivan
cc
Subject
New message: "Nexus 7010 VSS"
iceteanolemon,
A new message was posted in the Discussion thread "Nexus 7010 VSS":
https://supportforums.cisco.com/message/3053376#3053376
Author : kevin.hu
Profile : https://supportforums.cisco.com/people/kevin.hu
Message:
Community Member
Re: Nexus 7010 VSS
So with vDC we can do etherchannel over two boxes, correct?
Community Member
Re: Nexus 7010 VSS
Yes, you can.  It is no different than creating etherchannel between two physical switches.
Community Member
Re: Nexus 7010 VSS
Just a tiny correction...
You do have 2 different Nexus virtualization technologies here:
VDC - Virtual Device Contexts
vPC - Virtual Port-Channels
With VDCs, you can create contexts on the device just like firewall security contexts. You can, for example, have an Admin context where you control the whole box and runs OSPF, and a DMZ context that has no routing protocol. They have absolutely no communication between them (you need a cable for that).
If you get a pair of Nexus 7k or 5k switches, you can configure them to act as a single switch but only for port-channels - that is, you will be able to build a port-channel from a third switch to both of them. This is called a virtual port-channel - or vPC.
2061
