Nexus 7018 F2 Card COS to Queue Mapping
rick505d3
The default COS mapping for F2 card with egress queuing 1P3Q1T is:
    # show class-map
   class-map type queuing match-any 1p3q1t-8e-out-pq1
      Description: Classifier for Egress Priority queue 1 of type 1p3q1t8e
      match cos 5-7
    class-map type queuing match-any 1p3q1t-8e-out-q2
      Description: Classifier for Egress queue 2 of type 1p3q1t8e
      match cos 3-4
    class-map type queuing match-any 1p3q1t-8e-out-q3
      Description: Classifier for Egress queue 3 of type 1p3q1t8e
      match cos 2
    class-map type queuing match-any 1p3q1t-8e-out-q-default
      Description: Classifier for Egress queue 4 of type 1p3q1t8e
      match cos 0-1
The requriement is to override the default values to this:
    match cos 4-5
    match cos 6-7
    match cos 2-3
    match cos 0-1
However, it gives the following error on application:
"ERROR: Changing egress cos2q map towards non default fault value is not allowed with M-series card present in the system"
We have combination of M1, M2 and F2 cards in the same chassis Nexus 7018 running 6.1(4a).
Is there a way around the error ? In particular, how to map COS 4 (VidConf/RT Interactive traffic) to PQ1.
Rick.
sean_evershed
Level 7
Level 7
The default queuing policies cannot be modified directly. There are two options that you can try:
1. Copy the default policy to a new policy and then modify the new policy.
2. Define a new policy with a unique name and apply it.
Don't forget to rate all helpful posts.
jkilleda
Level 3
Level 3
Hello Rashid,
CoS remapping is supported only in strict F-Series VDCs. It is not supported in F-Series/M1 mixed VDCs
