Nexus 7K F2 and Netflow
Is anybody successfully collecting Netflow from a N7K running F2 line cards with Sup1?  I'm on 6.2(6), I've applied the TCAM hardware ACL (which is still required in 6.2(6)) and no love.  In packet captures on the collector I see the CFLOW packets hitting the server, but the flowset fields in the capture contain the field descriptions (I think) rather than the actual data they are supposed to contain.  See the attached screenshot.  We are sending the export to SolarWinds NTA.
flow timeout 0
flow timeout active 60
flow exporter nta-exp
  description export netflow to SolarWinds NTA
  destination x.x.x.x use-vrf management
  transport udp 2055
  source mgmt0
  version 9
    template data timeout 30
flow record nta-rec
  description Netflow record for SolarWinds NTA
  match ipv4 source address
  match ipv4 destination address
  match ip protocol
  match ip tos
  match transport source-port
  match transport destination-port
  collect routing source as
  collect routing destination as
  collect routing forwarding-status
  collect routing next-hop address ipv4
  collect transport tcp flags
  collect counter bytes
  collect counter packets
  collect timestamp sys-uptime first
  collect timestamp sys-uptime last
  collect flow sampler id
  collect ip version
flow record netflow-orginal
sampler nta-sam
  description Netflow Sampler
  mode 1 out-of 1
flow monitor nta-mon
  description Netflow Monitor for STA
  record nta-rec
  exporter nta-exp
Applied as:
ip flow mon nta-mon input sam nta-exp to layer 3 interfaces (VLANs).
I've had both TAC and SolarWinds engineers looking into this, I suspect this is a Nexus issue more than SolarWinds though (if not a configuration problem).  I've already tried using the netflow-orginal template and switching to v5.
If this posts answers your question or is helpful, please consider rating it and/or marking as answered.
Everyone's tags (4)
bump?
I found another customer with
I found another customer with this same issue running 6.2.6 code and nothing worked until we upgraded to 6.2.8a - then all worked as expected.
680
