Nexus 7K license Requirements
I will be installing a new 7009+Sup2e that apparently brings "N7K-LAN1K9" Lan Enterprise license and for the implementation I will be needing 2 VDC's because I will have F2 and M1 cards on the same chassis,
with this combination how many VDC's will I have ?
From the link
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/licensing/guide/b_Cisco_NX-OS_Licensing_Guide_chapter_01.html
gattered from another discussion I come to the conclusion that I need "N7K-VDC1K9" to add more VDC's correct ?
Best Regards,
Bruno Fernandes
Everyone's tags (1)
Re: Nexus 7K license Requirements
You would be having 8 VDC (Including default vdc).
More info:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps9494/ps9372/data_sheet_c78-437306.html
VDC:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/nx-os/virtual_device_context/configuration/guide/vdc_overview.html
With having VDC license you tend to move from 4 to 8 VDC's.
Inayath
************Plz rate if this information is usefull*******************
Hi Inayath,
Sorry but I'm confused the link's are not 100% clear to me, so simplifying with LAN Enterpreise license I will have only one VDC available correct ? Or 4 VDC's ?
I have only "LAN Enterprise license" for this chassis/sup2e
Best Regards,
Bruno
VIP Super Bronze
If you are using sup 2e, you can have a total of 8 VDCs, one is for admin use and the other 7 can be used for anything else including storage VDC.  If you are connecting storage to your 7k, it will need to connect to F2 module, as the M series modules do not support storage.
Please find details below:-
1- Supervisor 2 supports 4 VDCs while Supervisor 2E supports 8
2- SUP2 will support 4+1 VDC at FCS (NX-OS 6.1.1) and SUP2E will support upto 8+1 VDC. The VDC upgrade is for SUP2E not SUP2.
Please check out the release note for more detail:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/release/notes/61_nx-os_release_note.html
3- Sup2 has 12 Gb of DRAM while Sup2E has 32 Gb of DRAM.
4- In regards to vDC, both Sup2 and Sup2E.  They both support 6 vDC and 1 admin vDC.  In the future, this number will grow to 8 vDC plus 1 Admin vDC (aka "stretched").
N7K-VDC1K9—Enables support for eight VDCs on the Cisco Nexus 7000 Series Supervisor 2E module. This is a new license. One license is needed per chassis. A separate license is not required for each supervisor module.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/release/notes/61_nx-os_release_note.html#wp539647
Inayath
Dear All ,
Dear All ,
We have purchased Nexus 7K with SUP 2E and LAN enterprise license and SAN & LAN Advanced license .
Can you tell me whether we can configure VDC using this features  as we did not purchase additional VDC license .
I am keenly waiting for your reply soon.
With regards
Erfan
498
