nexus 7K port-channel
ronipo
Level 4
Level 4
hello,
after creating a port-channel within a vdc and assigning interfaces, i can't shutdown individual ports
the port-channel is part of a vpc
i am testing it on version 5.1.5
any ideas?
roni
phiharri
Greetings Roni,
Which ports are you trying to shutdown? How exactly are you shutting down these ports - using 'shutdown' in (config-if) mode? Is the command rejected or any error given? Can you share a session log demonstrating your issue here?
/Phil
hi Phil,
i am trying to close a memeber ethernet interfcae in the port-chanel, using the shutdown cmd in (config-if)
there is no error message - nothing happens
here is the relevant config and the a 'shutdown' test
interface port-channel200
  inherit port-profile N5K-PC
  description vPC to N5K Port 1/9, 1/10
  switchport
  switchport mode trunk
  switchport trunk native vlan 111
  vpc 200
interface Ethernet1/9
  inherit port-profile N5K-Eth
  channel-group 200 mode active
  no shutdown
interface Ethernet1/10
  no shutdown
N7K# sh int eth 1/9
  Ethernet1/9 is up
N7K# sh int eth 1/10
  Ethernet1/10 is up
N7K# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
N7K(config)# int eth 1/9
N7K(config-if)# shutdown
N7K(config-if)# do sh run int eth 1/9
!Command: show running-config interface Ethernet1/9
!Time: Sun Dec 18 09:17:52 2011
version 5.1(5)
  no shutdown
N7K(config-if)#
thanks,
roni
