Nexus 7K Switch is displaying "%TACACS-3-TACACS_ERROR_MESSAGE: All servers failed to respond" error.
I seem to be getting this error every two minutes or so. Everything on the switch works ok, including tacacs (I can log onto the switch using my ACS account) so I don't see why I'm getting this error?
Can anyone assist?
Re: Nexus 7K Switch is displaying "%TACACS-3-TACACS_ERROR_MESSAG
What code are you running?
Do you have no ip domain-lookup configured?
jerry
We're running version 5.1.1.
We have "ip domain-lookup" configured. I believe there is an unspecified bug which means you cannot do a "copy run start" if you have "no ip domain-lookup" and no domain specified.
VIP Green
Hi James,
If you issue the test aaa command does it return an error, and if so what is that error?
-- Please remember to rate and select a correct answer
No errors are returned -
DS0102# test aaa server tacacs+ 10.184.100.45 0355414 ######## user has been authenticated
DS0102# test aaa group LTSB 0355414 ####### user has been authenticated
VIP Green
Have you configured shared keys for the TACACS?
Hi James,
You are hitting CSCtj83417 bug with this behaviour. This is fixed in 5.2(1) release posted on CCO.
HTH,
-amit singh
Amit, The only possible reason that it is hitting CSCtj83417 bug is ip domain lookup is configured after TACACS is enabled and configured. Otherwise, it doesn't match the condiction in the bug.
James, you are running a very bad code 5.1.1. You should upgrade it to 5.1.4 or so. If you are indeed hitting CSCtj83417, you can try a system switchover to see that goes away.
jerry
3024
